Workbench Ideas and Pictures
24 replies to this topic
#1 jc56 OFFLINE
jc56
  • 10 Thanks
  • 29 posts
Posted January 26, 2012 - 02:04 PM
I need to build a big,sturdy workbench.Has anyone used those resin legs from Northern Tool?If so,how did they work out?Other than that,has everyone used 4X4 for legs?I was thinking about building a 4X8 bench.Any ideas and/or pictures appreciated!!:help:
  • shanabo60 said thank you
#2 KennyP ONLINE
  • 38,195 Thanks
  • 45,842 posts
Posted January 26, 2012 - 02:56 PM
4X4's would be good, add some weight to hold it steady.
#3 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted January 26, 2012 - 03:08 PM
Just finished my workbench today, 29" x 92" and 3 foot tall (I'm 6' 2"). All of it from steel framwork and tabletop we had around here, so re-purposed them. The top bolts to the base as opposed to weld. It is about all Dad and I can move, so easily 300 pounds or better. I don't want to know LOL. Legs are 2x3 box tubing and all pieces between them are the same material. The top could have been thick plywood but we had a large metal table top of some sorts that we ended up using. Good luck on your bench.
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted January 26, 2012 - 04:02 PM
Unless you work on really large stuff a narrower- (24-32")- table may be better use of space. It's also useful to have shelves underneath if you don't need to move it. I have a 32x48 table with 4x4 wood legs and a 2" wood top that sits in the middle of my basement workshop and a 24x96" along one wall.
#5 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted January 26, 2012 - 04:31 PM
Sorry, I didn't see the request for pictures. Heres a couple, mess and all. I built the workbench at least 20yrs ago. It's a sort of a crude mortise and tenon construction. I used construction adhesive in the M and T joints to fill in the gaps. That method of construction is very strong. The top is lag bolted from the underneath and has a piece of sacrificial 1/2" MDF screwed to the top. I do woodwork on this and every few years when it gets beat up I change out the mdf and put a fresh coat of sealer on it.
#6 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted January 26, 2012 - 04:53 PM
Brian: are you on any wood working forums. nice mobile saw base.
#7 jc56 OFFLINE
jc56
  • 10 Thanks
  • 29 posts
Posted January 26, 2012 - 05:22 PM
Thanks to everyone.Nice pics Brian!!!I have a bench now that is about 30" by 60" or so and it seems that I am always frustrated that it is too small everytime I work on something.4 X 8 may be a little too big,but I didn't see any reason to waste lumber.If anybody else has ideas....send them on.Thanks guys!!
#8 KennyP ONLINE
  • 38,195 Thanks
  • 45,842 posts
Posted January 26, 2012 - 05:49 PM
I haven't any pics of mine by itself, but I'm using a 32" wide steel door set on a couple sawhorses. Works pretty good and easily moved out of the way.
#9 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted January 26, 2012 - 05:56 PM
Now THAT'S the Okie way.:urock::urock:
#10 Canawler ONLINE
Canawler
  • 1,948 Thanks
  • 1,802 posts
Posted January 27, 2012 - 08:31 AM
:DIt doesn't matter how big you build it, it will still be covered with stuff and have no usable space.
  • Toolpartzman said thank you
#11 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted January 27, 2012 - 08:41 AM
Right now I have 2 benches that are 4' by 2' and are old counter top pieces, they have 2x4 legs and 2x2 stiffeners. I also have a kobalt brand bench we bought from the previous owners of our house. I am getting into wood working a lot more and I am wanting to build a big and heave wood working bench that will probably have 6x6 legs, 2x6 stringers, and a top glued up from 2x4's.
here is a older picture right after moving in, while I was getting things settle in the shop. I think everything is in a different spot now.
#12 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted January 27, 2012 - 04:21 PM
Thanks for the compliment Chuck. I am not on any woodworking forums. I like to do woodwork but mostly end up doing home renovations and repairs. The tractor thing gets in the way lately as well. Another hobby is audio equipment and I have built stands for equipment as well as speakers and subwoofer cabinets. The mobile stand is handy. I saw one at a store one day and it was expensive and made of metal. I thought the design was rather clever and I set about trying to make one out of wood. It cost peanuts to make and gets the job done.
#13 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted January 27, 2012 - 04:57 PM
my wood working is getting in the way of the tractor hobby right now. I need a way to balance them.
#14 Reverend Blair OFFLINE
Reverend Blair
  • 501 Thanks
  • 952 posts
Posted January 27, 2012 - 07:43 PM
Something I find makes work benches a lot sturdier is letting the cross-members into the legs. Just adjust your saw blade to the depth of the lumber you are using for cross-members, make several cuts across the 4x4 in the area the cross-member will go, and knock the excess out with a chisel. I don't have pictures of that on this 'puter, but it cuts down on wobble. Good technique for fences and picnic tables too.
#15 Reverend Blair OFFLINE
Reverend Blair
  • 501 Thanks
  • 952 posts
Posted January 27, 2012 - 07:50 PM
Ah, found some fence pics that show what I mean.
