new toy need year information
23 replies to this topic
#16 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted January 27, 2012 - 10:45 AM
A good used T92 transmission can go for a few hundred bucks without a problem. It looks like you have another clutch bellhousing and maybe some other stuff, all good parts to have. Economy always painted their engines, as far as I know. If the gas tank is not the L shape its a 69-72 then.
#17 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted January 27, 2012 - 03:56 PM
It just came to me, does the other clutch you got with it have a metal I.D. tag on it?
#18 ohio pk OFFLINE
ohio pk
  • 9 Thanks
  • 23 posts
Posted January 27, 2012 - 06:02 PM
It looks to be a 68 or 69 to a 72. Im not sure when they switched from starter/generator to starter and a separate charging unit, you have a starter and rectifier. I think they switched in 68 or 69. Is the gas tank an L shape or a big thing over the entire engine? The engine is not original, i assume the original was the one on your trailer. The model is a 1614, 16 inch rear tires and 14 hp engine. There was one a decal on the dash that had the serial number on it, I see its missing in one of the pics. If you want to find the serial number, it SHOULD, I'm not saying it does, but it SHOULD have the number stamped into the frame under the body tunnel were your left foot goes. Its a nice tractor you have and it will do a lot for you!
Could you post some pics of the stuff on the trailer in this pic? It looks like you have another tranny behind the engine and that's worth a lot of money if its in working condition.
ohio pk economy tractor - Garden Tractor Talk Gallery
i just took the pics of the parts i have for the tractor.
#19 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted January 27, 2012 - 06:21 PM
It looks like you have everything mechanical in front of the drive shaft! Did you happen to look and see if it had an id tag on the clutch?
#20 ohio pk OFFLINE
ohio pk
  • 9 Thanks
  • 23 posts
Posted January 27, 2012 - 06:29 PM
no tag there
#21 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted January 27, 2012 - 06:32 PM
Well, at least we could narrow down the year to a few possibilities. That's the problem with putting the serial numbers on stickers...
#22 ohio pk OFFLINE
ohio pk
  • 9 Thanks
  • 23 posts
Posted January 27, 2012 - 08:24 PM
Well you have helped alot with this so far. And i will probably be picking all your brains for more info as i go. Thanks so much and maybe i will be able to answer some questions also ( maybe ) .
#23 timtractor OFFLINE
timtractor
  • 224 Thanks
  • 376 posts
Posted February 02, 2012 - 09:31 AM
:wave: You have a nice looking tractor.
I think the year of your tractor is a 1969 or 1970. The model you have is called a 1614.
The model means that you have 16 inch tires and a 14 horsepower engine.
The problem with your tractor is that you are missing the ID tag on the dash.
eco1.jpg The tag should be between the two upper bolts on the dash.
The other thing that shows what year it is by the style of how far the hood goes down on the sides.
Here is a picture of my 1970 2414.
1105111427a.jpg My frame was lengthen to allow for another brand of deck.
#24 timtractor OFFLINE
timtractor
  • 224 Thanks
  • 376 posts
Posted February 03, 2012 - 10:08 AM
:wave: This is what my ID tag looks like on the dash of my Economy.
