Sears Kinda Weekend. Update
sears ss10 3 point tiller sears tiller roto spader
41 replies to this topic
#16 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted January 24, 2012 - 07:58 PM
Well, at least now we know, that you didn't save a planter box. :poke:
:bigrofl:
Nope, that's what we use the old toilets for...
#17 BushBoneYard OFFLINE
BushBoneYard
  • 36 Thanks
  • 70 posts
Posted January 24, 2012 - 08:01 PM
This may help?
  • MH81, caseguy, bhts and 1 other said thanks
#18 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted January 24, 2012 - 08:03 PM
Maybe those part numbers will give me a clue to search for.
#19 bhts OFFLINE
bhts
  • 1,460 Thanks
  • 2,156 posts
Posted January 24, 2012 - 08:06 PM
This may help?
Thanks i have looked everywhere and never could find info on it.
#20 bhts OFFLINE
bhts
  • 1,460 Thanks
  • 2,156 posts
Posted January 24, 2012 - 08:07 PM
Glad you like it Alan.
#21 BushBoneYard OFFLINE
BushBoneYard
  • 36 Thanks
  • 70 posts
Posted January 24, 2012 - 08:30 PM
No problem at all. Glad to help.
#22 olcowhand ONLINE
  • 39,674 Thanks
  • 30,972 posts
Posted January 24, 2012 - 08:35 PM
The prefix "235" points to Ingersoll Rand???
Sears Model Number Codes - Pro Tool Reviews Discussion Forums
#23 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted January 25, 2012 - 07:18 PM
I just got an answer back from Sears regarding the Tote.
We no longer have any information on the model number you provided. I do know that this tote bolts onto the front of the Suburban tractors (from the early/mid 70's). From what I can remember, the arms will go above the axle down the sides of the chassis and bolt to the frame.
I wish I had more information on this but I'm afraid we just don't have much on these older obscure items.
Thank you for using Manage My Life!
I don't think this is for a Suburban, the width is all wrong. It may still be for the Custom series, won't know till I get back in to one & take a couple of measurements.
#24 Gibby OFFLINE
Gibby
  • 96 Thanks
  • 360 posts
Posted January 26, 2012 - 11:55 AM
I uploaded 3 manuals in the manual section for the Sears Front Tote, hope that helps.
66-72 Suburban and 73 ST Tote
66-72 Custom & Compact Tote
GT Series Front or Rear Tote
  • olcowhand, MH81, Texas Deere and Horse and 1 other said thanks
#25 KennyP ONLINE
  • 36,448 Thanks
  • 44,935 posts
Posted January 26, 2012 - 12:08 PM
I downloaded and saved all 3.
#26 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted January 26, 2012 - 12:28 PM
Gibby, thank you very much. With that info, I'm pretty sure I can make a new bracket to work with the 12.
#27 Hugh OFFLINE
Hugh
  • 171 Thanks
  • 171 posts
Posted January 26, 2012 - 12:32 PM
That box IS a factory attachment, used to carry around light to medium weight things like tools, hoses, mulch and dirt. Think of it as a front mounted wheel barrow.
It appears as though you are missing some hardware.
  • mjodrey, MH81, KennyP and 1 other said thanks
#28 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted January 26, 2012 - 03:15 PM
Hugh, That's a great piece!
Could you do me a favor & measure the inside to inside of the arms that come back? Want to make sure I'm working with the right width to start with.
#29 Gibby OFFLINE
Gibby
  • 96 Thanks
  • 360 posts
Posted January 26, 2012 - 09:17 PM
Here is a picture for mounting reference, it appears as though you are missing some hardware.
Hugh, I forget, did you have a tote as well as James?
#30 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted January 29, 2012 - 11:44 PM
Update: went up to Dads and raided the cabinet. Had one good coil left, scavenged a push rod, put it all together & nothing.
No spark at all. Try this, try that, screw around, nothing.
Finally, I took the new points out and hit them with emery cloth (had used a points file earlier).
Put it in & WAAAHOOO! We have a very good looking spark. IDK if it was the points or maybe they weren't getting a good ground? At this point, it really doesn't matter, just curious.
I do need to take the flywheel off (if I can, it's really tight) and find a shim for the tapered crank bearing. Just a little slop, not to much, just enough to make me want to do something about it.
For now, I'm just happy to have a good, blue spark. :dancingbanana:
Also tagged with one or more of these keywords: sears ss10, 3 point tiller, sears tiller, roto spader
