rear snow blower for a john deere 318
25 replies to this topic
#1 nbent ONLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted January 24, 2012 - 05:39 PM
I have a john deere 318 that has a snow plow on the front and a snow blower on the front. I was wondering if you guys had and thought no how it could be powered.
http://gardentractor...&imageuser=8649
Sorry new to the site you have to open the photo link to see pictures.
Edited by MH81, January 24, 2012 - 09:19 PM.
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted January 24, 2012 - 07:57 PM
Welcome to GTTAlk. Do you mean you want to convert the front mounted blower from a rear mounted one? I would start by looking at any tillers that JD made for the back and seeing if you could use something similar to drive the blower.
#3 MH81 OFFLINE
  • 29,978 Thanks
Posted January 24, 2012 - 09:22 PM
:welcome: to GTTalk,
Thanks for the pics (fixed your links for you) hopefully someone has a cleaver idea... These guys are pretty smart.
  • nbent said thank you
#4 nbent ONLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted January 25, 2012 - 06:04 PM
thanks for fixing the pictures. I am taking a front mount snow blower from an Areins tractor and putting it on the back of my 318. I have thought about tillers, and a rear pto but wanted to see if anyone else had ideas.
#5 poncho62 OFFLINE
poncho62
  • 2,113 Thanks
  • 1,780 posts
Posted January 25, 2012 - 06:07 PM
welcome....I am going to follow along with this thread, as I am interested in doing the same with my Ford tractor....It has a rear PTO, but need to figure what blower will work
#6 nbent ONLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted January 25, 2012 - 06:15 PM
I think if you had a plate that used the draw bar and holes for the 3 point arms you could use a setup like we used. If you found one similar to what I used it would be easy. All we had to do to mount it was make the plate for the draw bar and hock up the lift arms that were used for the deck.
looking around the shop and a junk yard i might do a hydraulic powered blower.
Edited by nbent, January 25, 2012 - 06:37 PM.
#7 poncho62 OFFLINE
poncho62
  • 2,113 Thanks
  • 1,780 posts
Posted January 25, 2012 - 06:28 PM
Yeah..maybe....Have to figure out things like the direction the blower pulleys etc turn in relation to my PTO etc.......
#8 cch246 OFFLINE
cch246
  • 1 posts
Posted January 26, 2012 - 10:26 PM
Deere 318s uses a pto type shaft to rear with pulley system to run their tiller basically like your blower sits I believe the shaft connects the transaxle somehow you should have live power, don't know but probally will spin the wrong direction, You would have to use a reverse jack shaft setup or twisted belt design of some kind. Do some research you might be able to build something similar.
#9 nbent ONLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted January 29, 2012 - 07:55 PM
I was doing other farm work today looked at the drive for a wheel move pipe line. I might do something similar to that so i could have extra hydraulics and have it reversible.
#10 nbent ONLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted March 23, 2012 - 09:40 PM
while the snow is gone the little we got. I am going to take the blower off and make front mud guards I think is what they are called I will try to upload a pic when they are finished.
#11 nbent ONLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted November 22, 2012 - 01:21 AM
well its been a while since I worked on this but i found a power steering pump out of an old dodge we have and i made a mounting bracket to run of of the front electric clutch will post photos tomorrow also found a hydraulic motor I am going to run the blower with now all I need is to put the motor on, make hoses, find a valve, and get some new belts and she will be ready for snow.
#12 mjodrey OFFLINE
Posted November 22, 2012 - 05:22 AM
Can't wait to see pics.
#13 shorty OFFLINE
shorty
  • 5,833 Thanks
  • 5,414 posts
Posted November 23, 2012 - 11:12 AM
This sounds interesting, let us know how it works when you get to use it. Kinda thinking about trying something like it myself. Will PS pump have enough flow to turn a motor?
#14 nbent ONLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted November 23, 2012 - 03:51 PM
I don't know if they will have enough power to or not, but i suspect so because people use them to power hydraulic rams.
Yesturday i was able to get a motor and belts for the pump, and found out that the pump doesn't work :wallbanging: so today im helping put in a clutch on a dodge pickup and in return I am getting the hydraulic system that was on an old front end loader, so i will have enough power to run the blower and a few other things
#15 shorty OFFLINE
shorty
  • 5,833 Thanks
  • 5,414 posts
Posted November 23, 2012 - 04:27 PM
That will definately be a big enough pump. Sounds like a fun project.
