Onan p218 engine
5 replies to this topic
#1 MOWERMAN12 OFFLINE
MOWERMAN12
  • 5 posts
Posted January 24, 2012 - 03:59 PM
Hello,anybody know of an outlet to get the plastic/nylon camshaft flyball spacer without popping for the whole camshaft gear assembly? [onan p218]
#2 bhts OFFLINE
bhts
  • 1,476 Thanks
  • 2,167 posts
Posted January 24, 2012 - 04:54 PM
On the front of the cam you will see a clip ring pull that off and then you can get to the nylon spacer.Just be carefull as all the balls on the cam will fall out when you do this.
#3 olcowhand ONLINE
  • 42,479 Thanks
  • 31,828 posts
Posted January 24, 2012 - 05:07 PM
Looks only to be available with the gear. I'll look in my used parts to see if I have a good one if you'd like.
#4 MOWERMAN12 OFFLINE
MOWERMAN12
  • 5 posts
Posted January 25, 2012 - 06:31 AM
Thanks, after making the post,I found one in the shop,thanks for the responce.
#5 MOWERMAN12 OFFLINE
MOWERMAN12
  • 5 posts
Posted January 25, 2012 - 06:33 AM
Thanks for the advice.
#6 olcowhand ONLINE
  • 42,479 Thanks
  • 31,828 posts
Posted January 25, 2012 - 09:48 AM
Glad you found one. Nothing better than "inventory"!
