Cub 3206
30 replies to this topic
#1 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted January 22, 2012 - 08:23 PM
Need a little help. Bought this today knowing it is locked up, The wheels will not turn, also was told the lever that let's it roll freely will not move. Will get it home tomorrow and hope to check it out. Hoping the rod is frozen. Any though will help.
#2 Bill56 OFFLINE
  • 842 Thanks
  • 2,179 posts
Posted January 22, 2012 - 09:54 PM
Don't have any ideas for you, Dale, but hope you have good luck "unsticking" things!
  • dstaggs said thank you
#3 olcowhand ONLINE
  • 42,507 Thanks
  • 31,838 posts
Posted January 22, 2012 - 09:56 PM
Pics, lots of pics. Maybe with pics, we can be of help you Dale.
#4 KennyP ONLINE
  • 40,236 Thanks
  • 46,811 posts
Posted January 23, 2012 - 06:25 AM
Get a pair of these to move it with until you get it straightened out:
#5 mjodrey OFFLINE
Posted January 23, 2012 - 06:27 AM
[ATTACH=CONFIG]28553[/ATTACH]
Hey that's good thinking ,Kenny.
#6 dstaggs OFFLINE
dstaggs
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted January 23, 2012 - 06:17 PM
If I have to have pictures guess it will be up to me to get it going as they don't tell me much. But Thanks Dan. First thing I will change the old gas to get the water out and it running good, Then will check the Hydro Pump, Seems like a good place to start. Went today with the redneck wrecker and picked the rear up and loaded it on trailer to get it home. It has a 20hp Kolher twin, Series 3000, Family SKH624U1G2RA, Model CH205, Spec 64631, Ser 2930701241.
#7 olcowhand ONLINE
  • 42,507 Thanks
  • 31,838 posts
Posted January 23, 2012 - 06:22 PM
Dale, the pics were just to familiarize myself to this model, as I don't know what type hydro or differential it has.
#8 olcowhand ONLINE
  • 42,507 Thanks
  • 31,838 posts
Posted January 23, 2012 - 06:23 PM
Dale, just looked it up on tractordata.com. Doesn't say the hydro make, but it has external brakes. Even if the hydro free-wheel valve is stuck, the axles should turn a little, albeit slow. I would take a look at the brakes being stuck solid.
#9 dstaggs OFFLINE
dstaggs
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted January 23, 2012 - 07:08 PM
Thanks when the back is picked up the wheels will turn. Did notice some water in the gas today so that will be the 1st thing then see if steering will work as it also is hyd. Think if it don't then the pump will be next. When I loaded it I picked up the rear. One good thing is do have good 20hp motor. Thanks
#10 dstaggs OFFLINE
dstaggs
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted January 24, 2012 - 07:41 PM
After cleaning the old gas and water out she purrs like a kitten. So now I know the steering will not work, Guess the Hyd. pump is out.
#11 olcowhand ONLINE
  • 42,507 Thanks
  • 31,838 posts
Posted January 24, 2012 - 08:01 PM
The pin in the charge pump may be sheared. Depends on what hydro you have how it is built. The charge pump supplies the hydro, plus does ALL the hydraulic functions of steering & implement lift.
#12 bhts OFFLINE
bhts
  • 1,476 Thanks
  • 2,167 posts
Posted January 24, 2012 - 08:31 PM
Dan if i remember correct the pump is a hydro-gear. I don't belive there is a sheare pin as the shaft is splined for the charge pump.
#13 bhts OFFLINE
bhts
  • 1,476 Thanks
  • 2,167 posts
Posted January 24, 2012 - 08:33 PM
Dale this may be a real dum question but have you checked the fluid in the rearend?
#14 olcowhand ONLINE
  • 42,507 Thanks
  • 31,838 posts
Posted January 24, 2012 - 08:34 PM
Bob, do you have a model # of that pump, or link to a diagram of it?
#15 dstaggs OFFLINE
dstaggs
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted January 24, 2012 - 08:48 PM
Yes and it full. Didn't have long this afternoon to play with it and can't read the numbers up on the side of the housing, If it didn't run HOT I don't know why as everything is caked full of crap.
