GTV/16 3-Point
205 replies to this topic
#91 KennyP ONLINE
  • 41,480 Thanks
  • 47,408 posts
Posted April 03, 2012 - 01:09 AM
Got the cylinder yesterday. Looks to be a 2" bore. 11 3/4" closed length. 3/4" pin hole on base. 7/16" hole on clevis end. I'll see about getting the fuel tank installed and see what space is left to install under there. Valve looks very similar to the one I already have.
#92 mjodrey OFFLINE
Posted April 03, 2012 - 04:46 AM
Glad you got your cyl,Kenny.
#93 KennyP ONLINE
  • 41,480 Thanks
  • 47,408 posts
Posted April 07, 2012 - 07:28 PM
Got things together today! Figured out where I could mount the valve. Going to be tight with the hoses, but it's handy!
#94 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted April 07, 2012 - 07:38 PM
That worked out really well. No fuss with the linkage and you have the lever right beside you where it's easy to use.
#95 KennyP ONLINE
  • 41,480 Thanks
  • 47,408 posts
Posted April 07, 2012 - 07:47 PM
I just hope I can run the hoses okay. the cylinder hoses will go thru the hole just to the lower right in pic #2. The pressure/return will go under the frame and back to the front.
#96 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 07, 2012 - 08:20 PM
Looking good Kenny, but wheres the other pics?? You know, of the tires.
#97 KennyP ONLINE
  • 41,480 Thanks
  • 47,408 posts
Posted April 08, 2012 - 05:48 AM
Tire pics are in the refurb thread, Casey! But here's one just for you:
This also shows what space I have to work with back there now. I gained about 3/4" per side in width, plus the 1" height under the fuel tank. Hope I can mount the cylinder in there.
  • wvbuzzmaster said thank you
#98 Michiganmobileman OFFLINE
Posted April 08, 2012 - 07:13 AM
Looking good Kenny, glad to see that valve get used, had been in my drawer for a few years too many.
#99 KennyP ONLINE
  • 41,480 Thanks
  • 47,408 posts
Posted April 08, 2012 - 07:33 AM
Greg, I'll use yours on the 3-point. The other has different fittings, may have to change them around for the cylinder. I think the flare type would be better, easier to get the twist out of the hoses.
#100 Michiganmobileman OFFLINE
Posted April 08, 2012 - 08:31 AM
OOPS, my bad. Sure look close though dont they?
#101 KennyP ONLINE
  • 41,480 Thanks
  • 47,408 posts
Posted April 08, 2012 - 08:42 AM
That's your valve in there, Greg. That is where I wanted it for the 3-point, close and the normal direction I turn to look at what I'm doing back there. The one that came with the cylinder is a match to it, though. Not sure where I can put it yet and don't have a cylinder for anything else.
  • Michiganmobileman said thank you
#102 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 08, 2012 - 09:40 AM
Looking awesome Kenny, so you going to get that 3 point on this weekend?
#103 olcowhand OFFLINE
  • 43,169 Thanks
  • 32,011 posts
Posted April 08, 2012 - 10:07 AM
Plenty room for the hoses to pass. I'd suggest jic #4 fittings & 1/4" hose. Plenty flow for the cylinder & hoses easier to deal with.
#104 KennyP ONLINE
  • 41,480 Thanks
  • 47,408 posts
Posted April 08, 2012 - 04:14 PM
I doubt that, Casey!
What's a JIC #4 fitting look like, Daniel? Something similar to this:
If so, that is what I would like to use. The cylinder and valve I bought online has an inverted flare fitting. Have to turn the hose to screw these in. Yuk!
Pic didn't come out so hot, but you get the idea, I hope!
I got a few things mocked up. Need some input on it all. I have lots of questions going on. Just want to know if this can be made to work.
#105 Michiganmobileman OFFLINE
Posted April 08, 2012 - 04:27 PM
I think it looks like it should work! I was looking at my brothers Kubota the other day and see it only has 1/4 inch lines on its loader. Isnt there a swivel adapter for those inverted flare ends someone? I am not real familiar with hydraulic terminology but I would call that a 3/8 flare fitting on the valve Kenny, but again not sure in Hyd term.
