GTV/16 3-Point
205 replies to this topic
#181 KennyP ONLINE
  • 40,080 Thanks
  • 46,745 posts
Posted April 19, 2012 - 07:02 PM
Brian, I was going for the wow factor. Between the charcoal grey and black will be a nice splotch of red. Ought to pop right out there! I'll definitely know it in a group!
#182 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 19, 2012 - 08:00 PM
See Kenny, I told you that you wanted to be just like me lol. I know I can always find the Caterpillar in a crowd of Craftsmans. When you are done with your GTV16 we need to post pics of our Craftsmans side by side by side with a stocker lol.
#183 DH1 ONLINE
DH1
    Electric Tractors
  • 5,357 Thanks
  • 5,603 posts
Posted April 19, 2012 - 08:11 PM
Everyday looking better and better, I like the Red, nice touch.
#184 KennyP ONLINE
  • 40,080 Thanks
  • 46,745 posts
Posted April 20, 2012 - 06:11 AM
Casey, all I will have for a 'stock' tractor is the before pics unless I 'borrow a pic from elsewhere.
Doug, I thought the red would help bring out the other colors. Needed something to break up all the dark color!
#185 IamSherwood OFFLINE
  • 8,395 Thanks
Posted April 20, 2012 - 06:19 AM
With that red in there, it looks like a little massey interaction happened. Looks good.
#186 KennyP ONLINE
  • 40,080 Thanks
  • 46,745 posts
Posted April 20, 2012 - 06:27 AM
Guess I should have updated the 'Refurbish' thread with some of these pics. I'll do that with today's pics.
Will, could have been! I like the looks of the 12, 14, & 16 Masseys.
#187 JDBrian OFFLINE
  • 9,640 Thanks
  • 14,156 posts
Posted April 20, 2012 - 10:05 AM
Could be Will. Those Masseys just can't seem to leave other tractors, Bushhogs for instance, alone. Maybe one got into Kenny's Barn and had it's way with the Sears!!!
#188 KennyP ONLINE
  • 40,080 Thanks
  • 46,745 posts
Posted April 20, 2012 - 04:00 PM
Brian, haven't seen any Massey's around here. One could have snuck in while it was in Wichita!
#189 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted April 21, 2012 - 09:41 AM
Let's hope our GT Gene Pool hasn't been hurt
#190 KennyP ONLINE
  • 40,080 Thanks
  • 46,745 posts
Posted April 26, 2012 - 11:24 AM
Just an update. The guys are spraying primer on the '56, so I had to cover everything and put this on hold again!
#191 Michiganmobileman OFFLINE
Posted April 27, 2012 - 09:50 PM
Wow Kenny thats looking really sharp! Nice progress :thumbs:
#192 JDBrian OFFLINE
  • 9,640 Thanks
  • 14,156 posts
Posted April 28, 2012 - 06:07 AM
Kenny, I had the 2320 out the other day and measured the amount of lift it has. The arms are adjustable and I have them in the position that gives the highest lifts and the largest amount of lift. Even in this position it produces only 20" of lift. I think 16" is the standard amount for a cat 1 so your cat 0 is producing a lot of lift. If you have a problem with not being able to lift enough weight with your current setup you might consider making the arms adjustable like the 2320. I've included a couple of pictures of the setup.
You can also see how the anti sway setup works. The 2 turnbuckles adjust the side to side slack out of the arms. JD provides a difficult to use locking pin to keep them locked in place. Without some sort of lock they tend to loosen quickly. I run a couple of bungie cords, which you can see in the second picture, up to the top link instead. This keeps all 3 adjustments from moving and it's easy to adjust by simply removing the bungie cords. It is necessary to keep them tight because I am using a 600lb ballast box which if left loose will swing from side to side and can damage the 3pt mount when it fetches up.
#193 KennyP ONLINE
  • 40,080 Thanks
  • 46,745 posts
Posted April 28, 2012 - 07:09 AM
Thanks, Brian! I don't have too much side sway, they won't reach the tires. May be a while yet before I can get the hoses plumbed in and get to try it out. I have put some plugs in the openings for now, keep dust and bugs out. But, I got it running and brought it home for now. I'll most likely have to take it some where to get the hoses made up.
#194 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted April 28, 2012 - 07:20 AM
Kenny, do you have a local Parker hose dealer near by?
#195 KennyP ONLINE
  • 40,080 Thanks
  • 46,745 posts
Posted April 28, 2012 - 07:48 AM
Yes, about 3 miles away.
