GTV/16 3-Point
205 replies to this topic
#136 IamSherwood OFFLINE
  • 8,395 Thanks
Posted April 12, 2012 - 07:16 PM
Kenny, any way you can incorporate some sort of a skid plate/protector under that cylinder.
With that little ground clearance, I think it'd be worth the effort.
#137 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 12, 2012 - 07:24 PM
Looking good Kenny. Curious to see it all working.
#138 KennyP ONLINE
  • 41,485 Thanks
  • 47,409 posts
Posted April 13, 2012 - 03:28 AM
Looking into that, Will. I'll still have around 7.5-7.75" clear.
So am I, Casey!
#139 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted April 13, 2012 - 03:49 AM
You cant tuck that cylinder up in there a little higher and closer to the axle ? Or is it already at the axle?
Raise it up so the rod is parallel to the arm and nail it! As for the center link mounts that's easy, if you want you could do like the massey has, but personaly I would make a set of 3 holes lower, you will gey more lift at the rear of the implement.
#140 KennyP ONLINE
  • 41,485 Thanks
  • 47,409 posts
Posted April 13, 2012 - 04:18 AM
I am making the lower mount with the rod thru it. With that, I can see if it will swing back up and under more, but I don't think much more. I don't want it interfering with the pin for the lower link and the rear end is real close on the inside. The mount has to be wide enough to provide clearance for the hose to hook up at the bottom, So right close to where it is will probably be the final spot It took a bit of thinking to figure out how to hang the inner side of the mount. I'll know more today. It was the end of the day before I got the hangers bored to 3/4" for the rod. All I have to get that size hole is a bi-metal hole saw.
#141 KennyP ONLINE
  • 41,485 Thanks
  • 47,409 posts
Posted April 13, 2012 - 05:32 PM
Well, things look a bit different as of today! Got the adjuster links completed and the rock shaft hooked to the lower arms. Got some adjusting to do. Upper limit is 19.5", lower is 2". I know how to correct this and will have that done tomorrow. Then I can concentrate on the cylinder mount. After that, it is the pump mount. Then find somewhere to get hoses made. Ahhhhh, progress is sweet.
Oops, almost forgot the pics:
#142 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 13, 2012 - 05:34 PM
Glad to hear you are making progress Kenny.
#143 Michiganmobileman OFFLINE
Posted April 13, 2012 - 05:54 PM
Looks like real good progress Kenny :thumbs: , I like that stack of blocks in the first picture, looks like one of my temporary supports when my favorite lifting tool is not within reach (or I am too lazy to get it).
I got an old fashion bumper jack (favorite lifting tool) from the local auto junkyard, the type that had a hook that fit in a slot on the car bumper. I can use it with just the hook or hang a chain on the hook for a different connection. I put a pin through the base to keep it on then screwed the base to a piece of 2 x 6 for stability. I use it all the time for lifting this or that. In your case stick a piece of re-rod through your swivels and your ready to go. Just thought I'd mention that, works good for me. :)
#144 KennyP ONLINE
  • 41,485 Thanks
  • 47,409 posts
Posted April 13, 2012 - 06:10 PM
I just haven't looked for something to go across and the blocks are easy to move out of the way. It's coming along, quite the learning curve working here. Not as simple as I thought it would be. But I will enjoy it when I'm done.
#145 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,467 Thanks
  • 5,625 posts
Posted April 13, 2012 - 07:37 PM
Looks like your getting somewhere with this 3pt, you got to build yours from scratch, the one I'm working on is already done just made for a different model, I got it easy.
#146 KennyP ONLINE
  • 41,485 Thanks
  • 47,409 posts
Posted April 13, 2012 - 07:42 PM
LUCKY!!!!!! I'll get there, just a bit slower.
  • DH1 said thank you
#147 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted April 14, 2012 - 03:02 AM
Looking good Kenny, most folk don't realize what it takes to make one from scratch ;)
#148 KennyP ONLINE
  • 41,485 Thanks
  • 47,409 posts
Posted April 14, 2012 - 06:33 AM
I did opt for the split collars to get things set up. That was a good move. I have some interference points, especially the upper limit. I'll take it apart this morning and fix that.
#149 KennyP ONLINE
  • 41,485 Thanks
  • 47,409 posts
Posted April 14, 2012 - 02:22 PM
Got rid of the interference problems! I now have free movement from 3.5" to just over 20". WooHoo! Took the afternoon off to celebrate!
#150 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 14, 2012 - 02:29 PM
Great to hear that Kenny. So now comes pumps and plumbing. :D
