Allis 410 refurb
72 replies to this topic
#46 olcowhand ONLINE
  • 40,329 Thanks
  • 31,166 posts
Posted October 10, 2012 - 06:37 PM
Looks like the green belt isn't worn...just a 1/2" wide belt vs a 5/8" blue one. I think it just had the wrong belt to begin with.
#47 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted October 10, 2012 - 07:04 PM
According to the part no. in the parts list and also in the Belt & Blade Reference for the 410, it should be a 1/2" wide belt.
#48 olcowhand ONLINE
  • 40,329 Thanks
  • 31,166 posts
Posted October 10, 2012 - 07:12 PM
That's what I was thinking, as it was a 1/2" belt on my Allis 416. The pulleys will allow a 5/8 belt, but the 1/2" belt is designed to run deeper in the pulleys so the pulley sides help guide the belt into the groove. That is needed with the twist the belt has while going through the mule idlers especially, but also for the pto clutch & deck center pulley. A 5/8" belt may actually wear out quicker, or run itself off a pulley.
#49 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 11, 2012 - 06:00 AM
I couldn't find the belt size. I even looked in the service manual. The old belt measured about the 3/8" mark on the belt measurer. Hopefully the 5/8" x 50" belt I used doesn't do any damage.
Sent from my HTC One X
#50 sammiefish OFFLINE
sammiefish
  • 8 Thanks
  • 26 posts
Posted October 15, 2012 - 08:23 PM
what belt are we talking about... the variable has the big wide belt and the deck belt is 81" or 82"...
Im lost... did I not go back far enough in the post... did this have the variable removed?
Summer is slowing down so it's time to do a little more work. I noticed the belt slipping the other day. Amazing how worn the belt is.
#51 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted October 16, 2012 - 05:38 AM
Chris, I believe you're thinking about the 310 instead of the 410, since you mentioned the variable. Drive Belt on the 410 with standard transmission pulley should be a 49.1" HA (1/2" X 49") belt.
#52 sammiefish OFFLINE
sammiefish
  • 8 Thanks
  • 26 posts
Posted October 17, 2012 - 08:46 PM
Oh, sorry, nevermind...... : )
#53 boyscout862 ONLINE
  • 12,518 Thanks
  • 9,028 posts
Posted October 19, 2012 - 10:21 AM
Thank you for documenting your restoration. The work others are doing helps to motivate me on my Big Ten. If anyone is interested there is one for sale in Providence, RI at http://newlondon.cra...3341229012.html .
#54 quad_man10 OFFLINE
quad_man10
  • 4 Thanks
  • 46 posts
Posted October 22, 2012 - 08:57 AM
Hey Boyscout,
I have been looking at this tractor for a couple days now and have finally deiced to go take a look tomorrow. As i will also be going down to meet a member from here and get his Toro 3in1 that is for sale in the parts area. I will let you know how it goes.
#55 quad_man10 OFFLINE
quad_man10
  • 4 Thanks
  • 46 posts
Posted October 22, 2012 - 05:48 PM
Does anyone know how much a 410 weighs? I saw in the manual the 310 weighs about 800pounds!!! Thats way more than i would have thought. I could not find the 410 weight anywhere.
Sorry to highjack your thread. I did not want to start a new one for a simple question.
Thank you very much for posting all the great information you did and everyone else did. Its great to see how things should be so i can get an idea at what i am looking at.
Thanks
#56 boyscout862 ONLINE
  • 12,518 Thanks
  • 9,028 posts
Posted October 22, 2012 - 06:50 PM
Simpletractors.com says 780 to 825 pounds. Check it out http://www.simpletra...s/410_specs.htm . Have a safe trip.
#57 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 23, 2012 - 09:17 AM
I had to push it on a trailer one time. It was hard. Lol
#58 quad_man10 OFFLINE
quad_man10
  • 4 Thanks
  • 46 posts
Posted October 23, 2012 - 04:26 PM
I went down today and got the tractor. I can't wait to get it going. I will not be doing a full restoration, but i will get everything in working order. I wish i had a trailer. It took me, my brother, and the seller to load it. We used a set of ramps, a comealong, and brute force. Overall it was worth it. I will be sure to start my own thread once i start working on it.
#59 boyscout862 ONLINE
  • 12,518 Thanks
  • 9,028 posts
Posted October 23, 2012 - 09:54 PM
Congratulations. Start with before pictures. Good Luck.
#60 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,835 Thanks
  • 2,330 posts
Posted October 23, 2012 - 10:49 PM
Looked pretty good in the pickup. Best of luck with it!
