Chor trac montgomery wards 2 wheel tractor
5 replies to this topic
#1 MOWERMAN12 OFFLINE
MOWERMAN12
  • 5 posts
Posted January 20, 2012 - 10:17 AM
Hello, I am working on a Chor Trac 2 wheel tractor,trying to determine the year and model number,the serial number on the tag is SIM-990079A,I want to try to download a manual for it,it looks like there might be some brake parts missing any help would be appreciated,thanks very much,this is a great site.
#2 DougT OFFLINE
DougT
    Dog Approved
  • 7,075 Thanks
  • 5,058 posts
Posted January 20, 2012 - 10:38 AM
Mowerman12, Welcome to GTTalk!!! All I can tell you from your number is that it was built by Simplicity. If we could determne the Simplicity model we should be able to find a manual. Can you post a pic of it?
  • MOWERMAN12 said thank you
#3 brokenfeather OFFLINE
brokenfeather
  • 25 Thanks
  • 164 posts
Posted January 20, 2012 - 12:17 PM
Yes pictures by all means. Please. All most forgot to welcome you to the site.
#4 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted January 20, 2012 - 12:32 PM
welcome mowerman12,
Its hard to pin point the exact yrs of these tractors. If it has a briggs engine then one could run that number and get with a couple of yrs. Just from seeing several tractors over tiome i'd guess it to in the mid to later 50's. Im however interested in seeing a picture it, as a braking unit on a walk=behind is fairly rare. Since you are calling it a Chore-Trac i assume it has that on an oval shaped tag on the side of the frame or gear case? There were several "Trac" model built or the yrs.
#5 Billygoat OFFLINE
Billygoat
  • 76 Thanks
  • 206 posts
Posted January 20, 2012 - 03:50 PM
May want to check with Huntingrust. I believe he drug one home from the honey hole he showed me.
#6 MOWERMAN12 OFFLINE
MOWERMAN12
  • 5 posts
Posted January 20, 2012 - 04:58 PM
Thanks I'll try to post a picture asap,also thanks for the welcome.
