single cylinder analog tachometer
19 replies to this topic
#16 brokenbudget OFFLINE
brokenbudget
  • 19 Thanks
  • 178 posts
Posted January 19, 2012 - 07:44 AM
I tried a TinyTach on my Kohler and it was all over the place it was getting interference from the ignition system somewhere.
were you using a length of wire from it? or just the tach over the plug?
i use the sendec on my wheelhorse 312 with the wire with zero problems, however if i use my etd8 (stihl edt 8 tach) over the plug i get the same results as you.:shoot2:
#17 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted January 19, 2012 - 03:42 PM
You can use a tach off a harley with points
#18 brokenbudget OFFLINE
brokenbudget
  • 19 Thanks
  • 178 posts
Posted January 19, 2012 - 03:57 PM
you know, i was thinking that last night:D the cylinders fire at the same time, they're a bettery ignition, and are about the size i would need. plus, they would have the backlighting and sort of 'water resistant' feature i like when snow bowing after dark.
thanks for the reminder!:beerchug:
#19 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted January 19, 2012 - 04:20 PM
I was using the wire around the plug wire. I think the problem was the points arcing just a tiny bit. I have one on my standby generator and it works good
#20 brokenbudget OFFLINE
brokenbudget
  • 19 Thanks
  • 178 posts
Posted January 19, 2012 - 06:07 PM
could be the point flaring, never experienced that making a tach act up, but possible.:smile1:
i figured i could use this: Equus - Products - 6086 2-1/2
it's way cheaper than the 'msrp'. i can have it for 35-40 bucks depending on where i buy it from. has the inductive pick-up, so it don't really matter how many cylinders you
have:shoot2: just ain't weather proof, but that can be fixed also:smile1:
