my steering coloumn brace
18 replies to this topic
#1 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted January 15, 2012 - 04:55 PM
One of the few problems with power kings are the unsupported steering columns. A lot of people use the steering wheel to pull themselves onto the tractor, over time the column starts to become weak and move, or break the aluminum case it goes into... not cheap. On my 71 it wobbles some and it rotates as well as slides up and down about 1/2 inch. I decided to make a brace for the column to support it.
here it is, nothing was tight when i took the pics.
it seemed like bending the top right corner at perfect angle took forever!
I still have to sand and paint it, but that wont take long. Then I can make a brace for my 75.
if you dont have a support on your power king, I STRONGLY suggest making one before something breaks. A new steering box case can run you up a few hundred bucks.
  • ducky and MH81 have said thanks
#2 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted January 15, 2012 - 05:22 PM
Nice job!! :thumbs::thumbs::thumbs:Al
#3 mjodrey OFFLINE
Posted January 15, 2012 - 05:54 PM
That should stiffen it up.
#4 MH81 OFFLINE
Posted January 15, 2012 - 08:20 PM
Thanks for posting that. It could well save someone a pile of $ and a bunch of heartache.
#5 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted January 15, 2012 - 08:21 PM
thanks! And yes it will make it much stronger, just when it was loosely bolted on (the bolt on the top that goes int the dash didnt even have a nut on it.) it would not move, but its not like I pulled very hard on it.
#6 olcowhand ONLINE
  • 41,134 Thanks
  • 31,413 posts
Posted January 15, 2012 - 08:46 PM
Such a massive plate the box is bolted to, & then leave the column unsupported. :confuse:
That type of overlook can be found in many makes. Good job of reinforcing things!
#7 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted January 15, 2012 - 09:01 PM
Great upgrade, glad it worked out well for you.
#8 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1,805 posts
Posted January 15, 2012 - 10:23 PM
Nice job!! That has always been a weak point on the PKs and I have yet to fab up something for mine to strengthen it.
#9 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted January 16, 2012 - 12:11 AM
Thanks, mine is a little more elaborate than it needs to be but I suppose... if its worth doing, its worth over doing. I hadn't noticed how many vise marks I made until I sanded it!
#10 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted January 16, 2012 - 01:29 AM
That is a good idea. Going to look at that on mine as well. Thanks!
#11 KennyP ONLINE
  • 38,304 Thanks
  • 45,899 posts
Posted January 16, 2012 - 04:56 AM
That is pretty neat, Ryan. You did a fine job on that brace. Thanks for sharing it.
#12 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted January 16, 2012 - 01:57 PM
thanks, ill post pics of the painted part in a few minutes.
#13 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted January 16, 2012 - 02:16 PM
got it painted and put on, steering column has no movement whatsoever and its very sturdy.
this is what you would see from on the tractor.
it doesn't look much different with paint than it did without paint but at least it wont rust.
#14 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted January 16, 2012 - 03:05 PM
Good stuff. I can't help but open modification threads.
And you got it from both sides as well.
#15 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted January 16, 2012 - 07:11 PM
Looks even better installed, glad you were able to get the paint to it.
