* * * * * 1 votes
Different type of project
194 replies to this topic
#91 KennyP ONLINE
  • 38,284 Thanks
  • 45,886 posts
Posted January 26, 2012 - 11:43 AM
Give it a try, Chris. May be the camera angle making it look odd to me.
Thanks, ducky. I'm just concerned about when a load gets put on it.
#92 Cvans ONLINE
  • 6,643 Thanks
  • 6,127 posts
Posted January 26, 2012 - 12:40 PM
I just put an angle finder on the cylinder to see if I could give you a better answer. With the bed down the cylinder is at 58 degs. from horizontal and with the bed up it is at 47 degs. This does not take into account that the tractor tends to be slightly nose down.
#93 timtractor OFFLINE
timtractor
  • 224 Thanks
  • 376 posts
Posted January 26, 2012 - 01:26 PM
Chris
You really have a good looking project. :smile1:
I just found this page so I might be a little behind (nothing unusual). It would be nice to see if I can get you to bring it to some of the shows this year. The other guys in this area will probily be jealous of you.:bounce:
  • Cvans said thank you
#94 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted January 26, 2012 - 06:16 PM
The lifts that have the most problems are the scissor lift. I don't think he could put enough weight in the bed to overload the cylinders. Now if the cylinders break over center, he would have a problem.
#95 Cvans ONLINE
  • 6,643 Thanks
  • 6,127 posts
Posted January 26, 2012 - 06:23 PM
Good news. I put 440 lbs. (my Son and I) on the front of the bed and it lifted us with no problem. He was able to stiff arm one of the rafters and stop it with both of us on it. Didn't load the engine so I'm thinking the by-pass in the hydro is opening. I'm guessing it will dump anything I plan to haul. Takes 3 1/2 seconds to go from horizontal to almost vertical. Much faster than I ever imagined. I will try taking a video and post it here. I may need some help. Hint hint.
#96 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted January 26, 2012 - 06:27 PM
Glad it worked and you were pleased with it Chris.
#97 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted January 26, 2012 - 06:29 PM
That sounds perfect Chris! Being able to strong-arm stop it is a good sign. It will lift anything you need, just as you said.
BUT.... :wewantvideo:
#98 KennyP ONLINE
  • 38,284 Thanks
  • 45,886 posts
Posted January 26, 2012 - 06:37 PM
That's great, Chris. Glad it worked out okay. Told you I've been wrong before.
#99 Cvans ONLINE
  • 6,643 Thanks
  • 6,127 posts
Posted January 26, 2012 - 06:51 PM
BUT....
OK I will go out see what I can do for a video.
#100 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted January 26, 2012 - 06:52 PM
That's the spirit! :-)
#101 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted January 26, 2012 - 07:13 PM
The relief valve on the ported tranny is set for 500-625 lbs. the cap between the forward/reverse relief valves is the lift relief valve.
Edited by Amigatec, January 26, 2012 - 07:28 PM.
#102 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted January 26, 2012 - 07:43 PM
Chris sent me the video to put on my youtube account, but youtube can't convert it, as it's a "Quicktime" video. Anyone know how to convert a .mov movie file?
#103 IamSherwood OFFLINE
  • 8,391 Thanks
Posted January 26, 2012 - 07:44 PM
How many psi is that pump capable of?
#104 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted January 26, 2012 - 07:47 PM
I don't know, but the charge pump on the non-ported pump is set for about 95 lbs and on the ported pump it is set for 200 lbs.
I had to go look it .
#105 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted January 26, 2012 - 07:48 PM
Hey, I could play it on QuickTime, but not put on youtube, so I just played it on my PC and took a movie of it with my camera! I forgot to turn my sound higher for camera to pick it up good.
  • Alc, Cvans, Michiganmobileman and 1 other said thanks
