* * * * * 1 votes
Different type of project
194 replies to this topic
#16 olcowhand OFFLINE
  • 41,150 Thanks
  • 31,416 posts
Posted January 15, 2012 - 08:41 PM
See Chris....now ya gotta build a C-cab!:D
#17 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted January 15, 2012 - 09:45 PM
I always liked the C-cab, too bad everyone is going that route nowadays, someone will have to be different lol.
#18 mjodrey OFFLINE
  • 2,355 Thanks
Posted January 16, 2012 - 05:15 AM
Yes,this will be neat.
#19 Cvans OFFLINE
  • 6,648 Thanks
  • 6,129 posts
Posted January 16, 2012 - 10:47 AM
I've got to take this one step at a time. Having a real hard time ignoring Daniels picture of the C-cab.
I'm using a 1450 hydro rear end with the pump to lift the bed. Will be using the original 149 valve and plumbing to control the lift. I had thought of using single action cylinders but I think I would run low on fluid. With double action cylinders I will be dumping oil back into the hydro as the bed lifts so hopefully I'll be good to go.
Today I'm going to by the center bearing for the drive shaft. I'm planning on mounting that carrier bearing on rubber mounts so it can accommodate flexing of the frame. Will also be doubling the rag couplers just in case. Have them made already so I might as well use them.
Your suggestions and opinions are appreciated!
Photos tonight.
#20 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted January 16, 2012 - 11:22 AM
Since it is already going to be long why not add a mid mount blade so it can be used as a grader as well. It would grade good with it's length.
#21 Cvans OFFLINE
  • 6,648 Thanks
  • 6,129 posts
Posted January 16, 2012 - 11:52 AM
Good thought!
My oldest son thinks I should put duals on it but I'm leaning toward the ATV tires I have for better traction.
#22 olcowhand OFFLINE
  • 41,150 Thanks
  • 31,416 posts
Posted January 16, 2012 - 12:09 PM
That will be a fairly long dump box, so duals would give a wider stance & possibly much more stability than single ATV tires, but then maybe the offset in the ATV rims will kick them out further? When a load doesn't start sliding out right away, it sure can cause the dump bed to sway to one side when she gets up there.
#23 mjodrey OFFLINE
  • 2,355 Thanks
Posted January 16, 2012 - 01:10 PM
Duals,now you're talkin'.
#24 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted January 16, 2012 - 04:22 PM
I was thinking the same thing! Lots of potential in this project.
#25 IamSherwood OFFLINE
  • 8,391 Thanks
Posted January 16, 2012 - 06:39 PM
Oh Yeah, I like it.
Duallies, grader blade, and C-Cab. This will be awesome.
You're going to be sooooooo busy.:smile1:
I hope you still have time to post.
#26 olcowhand OFFLINE
  • 41,150 Thanks
  • 31,416 posts
Posted January 16, 2012 - 06:59 PM
Inspiration! :D
This one is a real "C".
Edited by olcowhand, January 16, 2012 - 07:18 PM.
#27 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted January 16, 2012 - 07:03 PM
Use dual ATV tires, best of all worlds.
#28 IamSherwood OFFLINE
  • 8,391 Thanks
Posted January 16, 2012 - 07:41 PM
Inspiration! :D
[ATTACH=CONFIG]28121[/ATTACH][ATTACH=CONFIG]28122[/ATTACH][ATTACH=CONFIG]28123[/ATTACH]
[ATTACH=CONFIG]28126[/ATTACH]
Yes, that is inspirational
#29 olcowhand OFFLINE
  • 41,150 Thanks
  • 31,416 posts
Posted January 16, 2012 - 07:44 PM
And a bit of pressure too! LOL
#30 HDWildBill OFFLINE
  • 8,975 Thanks
Posted January 16, 2012 - 10:15 PM
Yep, this is going to be an interesting project.
