Vote for Tractor of the Month
Murray Yard King 22.5-52" Question
2 replies to this topic
#1 JD DANNELS OFFLINE
JD DANNELS
  • 3,786 Thanks
  • 3,907 posts
Posted January 12, 2012 - 03:16 PM
Going to start here, since I was not sure if it should go in the "OTHER" or Implements. I'll get Model # tonight.
But I have a Yard King with the 22.5 Briggs V twin. It is a GT with Rail Frame and 1" axles(It has amazed me many times). I want to put a sleeve hitch on it and was wondering if I could run a link from the mower lift (in left Fender) back to the Hitch lift. It already has a notch in the rear frame plate it could pass through. Has anyone seen one of these with the Hitch mounted?
The Rocker is spring assisted and if the handle will take the lift, it should be pretty easy to hook up and look slick.
Forgot I had the model # in my computer it's a 99 model 52161x089A
Edited by JD DANNELS, January 12, 2012 - 04:20 PM.
#2 BushBoneYard OFFLINE
BushBoneYard
  • 36 Thanks
  • 70 posts
Posted January 13, 2012 - 06:00 PM
That machine should call for Hitch #24801. Your set up would be very similar to the one below.
#3 JD DANNELS OFFLINE
JD DANNELS
  • 3,786 Thanks
  • 3,907 posts
Posted January 14, 2012 - 05:49 PM
Thanks!
