Another JD400 Question, Little cover on top of engine seaping
16 replies to this topic
#16 bhts OFFLINE
bhts
  • 1,473 Thanks
  • 2,166 posts
Posted January 22, 2012 - 04:43 PM
On the inside pedal there is a steel pin that holds the pedal to the shaft on the inside of the frame which needs removed to take the pedal off the shaft. Once you get the steel pins out that holds all the different linkages on the shaft it should come out.
#17 nathanatfork OFFLINE
nathanatfork
  • 5 Thanks
  • 51 posts
Posted January 22, 2012 - 07:30 PM
Thanks! Must have missed that one. Ill get out there tomorrow and give it a try again.
