Wheel Horse Bronco 14 question
8 replies to this topic
#1 Jasper OFFLINE
Jasper
  • 15 Thanks
  • 42 posts
Posted January 09, 2012 - 08:37 PM
I have the opportunity to purchase a Bronco 14 but I don't know anything about this model. How powerful are the hydraulics, can they be used to run attachments, and are the attachments easy to find. The unit I'm considering is $225 obo and does not run. Is this a deal or too much.
#2 MH81 OFFLINE
Posted January 09, 2012 - 08:46 PM
If, by attachments, you mean like a loader or something, I would think it would be slow at the very least. The hydraulics are just for deck lift, sleeve hitch lift, etc. IDK if you can add more, but the system as it is is designed for small lifts.
Is the Kohler savable? If so, I think they are a little high, but I'm always amazed what WH collectors will pay :D. If not, I think they need to come down significantly.
All that said, a very similar unit with a running 12 Hp and the same hydraulics setup went for about a third of that last summer. Granted, the paint was no where near that good... But none the less, it ran. Pretty well actually.
#3 caseguy OFFLINE
  • 1,628 Thanks
Posted January 10, 2012 - 07:30 PM
Hey Jasper, I'm with MH81 on the value. The Bronco's aren't overly rare, or at least not more so than anything from that era. The hydraulics as Alan described are great for attachment lift, but the pump is small and slow, volume wise, for anything more than that. I wouldn't pay that much, but beauty is in the eye of the beholder, so that's your call. It's definitely a savable machine! Best of luck with whatever you decide! BTW, is the other front hubcap there?
#4 olcowhand ONLINE
  • 41,281 Thanks
  • 31,452 posts
Posted January 10, 2012 - 07:47 PM
That may have the solid state ignition, as I may see the coil just under & behind the starter. The GT14 had solid state & the parts are hard to impossible to get. However, most can have points added & switch to battery powered ignition. I would give $150 to $175 for it myself...tops.
#5 Texas Deere and Horse ONLINE
  • 14,815 Thanks
  • 15,502 posts
Posted January 14, 2012 - 08:42 PM
Sorry I missed this thread. If you can still buy it, it is worth the money. The electric PTO clutch is worth one hundred to one fifty. The ¹⁴HP Kohler will bring at least one hundred and fifty easy. I would try to buy it for less, but would take all of them I could find for that money....Good Luck
#6 546cowboy OFFLINE
546cowboy
  • 6 Thanks
  • 29 posts
Posted January 15, 2012 - 10:04 PM
If the engine is OK I'm with Brian on that. Bronco 14's are not that common around me. I had one last year and sold it and have been kicking myself ever since.
I see that those that thought the price was high live in PA.
I live about 80 miles from Wheel Horse USA AKA South Bend,IN and for some reason there are more horses on the east coast and especially PA.
If you watch Ebay at all the prices for vintage wheel horses are usually higher.
As for impliments. WH used that hydro for a long time through many years and many different models. No I wouldn't try to run a loader off it but it will work with pretty much anything else you want to use. That 14 hp. Kohler is a strong engine.
#7 Jasper OFFLINE
Jasper
  • 15 Thanks
  • 42 posts
Posted January 17, 2012 - 08:59 PM
Thanks for the response. I haven't bought it as it is about 3 hrs drive from where I live. It is still showing up on Cgaigslist Wheel Horse
#8 jay holt OFFLINE
jay holt
  • 1 Thanks
  • 8 posts
Posted March 23, 2012 - 08:55 PM
my personal favorite wh is the bronco 14. the one your looking at is a 71. it has push- pull throtle & choke cables, it may or my not have the racing stripe down the hood. the 72 had up & down throtle & choke controls. i paid 500 in 1993 for my 71 & 550 for my 72 delivered to the wh show last june. my advice is to buy it. jay
#9 jusjeepn OFFLINE
jusjeepn
  • 84 Thanks
  • 120 posts
Posted April 08, 2012 - 01:57 AM
So did you get it? If not, well sorry you missed it. I see you in SC and any WH down there is pretty rare from what I understand. I live just south of Cowboy and just bought one, non running, deck froze solid but only 2 holes, no tires hold air, rims rusted, paint shot but engine has compression fro $200. I already tested the electric clutch and it's good ($100), has all 4 hub caps ($100) and the rest is a gimme! :thumbs:
