Massey 14 14h.p kohler carb settings
11 replies to this topic
#1 ckjakline OFFLINE
ckjakline
  • 1181 Thanks
  • 1173 posts
Posted January 08, 2012 - 07:39 PM
Hello everone,I'm working on finishing the restoration on my dads 14.He had motor rebuilt by a pro.We were using it and the rod broke which i heard was common on these.When he picked motor up he didn't ask what was done to carb,Govener set or anything.Well anyway i have tractor running but when you increase throttle engine surges,and shuts off.I don't have service manual to look at.I want to check manuals here,but does anyone have any tips on setting up governer and carb,or know what causes engine to surge.Any help would be appreciated.I'v been working on this thing for over a year in my free time,which isn't much.
Thanks,
Craig
#2 ducky OFFLINE
  • 2312 Thanks
  • 4300 posts
Posted January 08, 2012 - 08:30 PM
Craig
I have no secrets other than the manuals recommendations.
Perhaps someone will be along with more than I can offer.
  • ckjakline said thank you
#3 DH1 OFFLINE
DH1
    Electric Tractors
  • 5495 Thanks
  • 5633 posts
Posted January 08, 2012 - 08:44 PM
Thanks,
Craig
I would tend to think that it is running to lean, I'd try opening up the high speed jet 1/2 a turn and see what happens.
Next I'd make sure the carb was getting fuel, check fuel filter and pump.
I'd also check the float, make sure it's clean and the level set right.
#4 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 08, 2012 - 09:31 PM
What's the initial settings supposed to be? 1 1/2 turns on highspeed, and 1 1/4 on low? Going by memory.
#5 DH1 OFFLINE
DH1
    Electric Tractors
  • 5495 Thanks
  • 5633 posts
Posted January 08, 2012 - 09:35 PM
I did a search and came up with
Low speed > 2+1/2 turns out
High speed > 3+1/4 turns out
#6 HowardsMF155 OFFLINE
  • 3079 Thanks
  • 3084 posts
Posted January 09, 2012 - 08:44 AM
Before I made any changes I would do the following: Start the engine and run it for about 5 minutes to let it warm up. You don't say where it surges. Run it at full speed, if it surges, start choking the engine and see if the surge steadies out. If choking steadies the surge, then you are running too lean with your main jet. Adust that until the surge stops. Then run the engine at idle, or fast idle if it won't slow idle. Again, if it surges, choke it to see if the surging stops. If it stops, your idle circuit is too lean and you need to richen your idle. I would start with around 1+1/2 turns on both screws if you are completely unsure of how the carb is adjusted or if it is not running.
#7 ckjakline OFFLINE
ckjakline
  • 1181 Thanks
  • 1173 posts
Posted January 09, 2012 - 06:38 PM
wow i'm a little off i have high speed at 2 and low at 1 1/2.
#8 ckjakline OFFLINE
ckjakline
  • 1181 Thanks
  • 1173 posts
Posted January 09, 2012 - 06:40 PM
It surges when i increase throttle i put choke on and it smoothes out.I have carb set to where the book says.It doesn't have any carb troubleshooting in it.
#9 ckjakline OFFLINE
ckjakline
  • 1181 Thanks
  • 1173 posts
Posted February 05, 2012 - 09:05 PM
Well i finally got a chance to work on dads 14 today.Engine was running to lean i had to give it another full turn from where i had it set.It runs good now no surging.It started to ping after i got it running.All i had to do for that was pry the flywheel screen away from shround.Thanks for everyones help.
Craig
#10 DH1 OFFLINE
DH1
    Electric Tractors
  • 5495 Thanks
  • 5633 posts
Posted February 05, 2012 - 09:12 PM
Glad to hear you got it running better, Good Stuff.
#11 HowardsMF155 OFFLINE
  • 3079 Thanks
  • 3084 posts
Posted February 05, 2012 - 09:19 PM
Great to hear you got it running. Thanks for letting us know.
#12 MH81 OFFLINE
  • 30052 Thanks
  • 29761 posts
Posted February 05, 2012 - 09:23 PM
Good news, thanks for the update.
