1050 Starter/Generator
1 reply to this topic
#1 gbrown OFFLINE
gbrown
  • 20 Thanks
  • 90 posts
Posted January 06, 2012 - 10:16 AM
I'm new here so apologies if this is posted in the 'wrong' place. I've got a 1966 1050 with the Wisconsin TR-10D and I'm looking for either starter parts or a complete used starter. The starter/generator is a Delco model 1101970. It seems that these are fetching a pretty penny online and I thought someone might have one they're not needing for a fair price or parts. Also, anyone familiar with which other tractors used this model starter? Perhaps if I found one on something else, it'd be cheaper? Any help/advice is greatly appreciated. Thanks.
#2 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 4971 Thanks
  • 2860 posts
Posted January 06, 2012 - 10:38 AM
Howdy, and welcome to this forum! ....There's a great buch of guys here, and the Manuals section of this site has lots of Bolens info.
Here is a link to a parts diagram & list for your starter/generator: Bolens / Delco-Remy starter parts - Manuals - Garden Tractor Talk - Forums
If you are anywhere near a rebuilder of starters & other automotive electrics, they should be able to test & repair your exisiting starter/generator.
These units are not very complicated, and many repairs can be done by anyone with a little mechanical & electrical knowledge.
Bearings are readily obtainable & easily replaced. ....Brushes are consumables which should be easy to obtain. .....Field coils can be replaced, if needed.
The armature is the most expensive and least easily-obtained part of the unit. .....If this needs to be replaced, you would be better to look for another starter.
The D/R # 1101970 starter/generator carried Bolens part #1716169, and was used on Bolens 800, 850, 900, 1000, 1050, and 1250 tractors. ....All of these models listed used Wisconsin engines.
I don't know which other brand tractors may have used the same starter, but the D/R parts list linked above will show which parts are interchangeable between different starter/generators.
  • NUTNDUN and Bolens 1000 have said thanks
