Help Replacement Engine for David bradley walk behind tractor
12 replies to this topic
#1 cid25136 OFFLINE
cid25136
  • 3 posts
Posted January 04, 2012 - 08:00 PM
"i have an old david bradley tractor 57560 which has a model 8 brigg and stratton engine...looking for replacement engine that has more power then the orginal engine and wil fit on the engine plate perfectly....":mad2:
#2 cid25136 OFFLINE
cid25136
  • 3 posts
Posted January 04, 2012 - 10:30 PM
I was told a Tecumseh 3 or a 5 hp snowblower engine will fit perfectly,,, does anyone know the model for both engine ?
#3 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted January 05, 2012 - 01:44 AM
welcome to the group. Unfortunatly what you want isnt going to happen, it could 100's of DB users would be throwiong away there old engines and going that way. I dont know the model for the tec blower engine, but if its a blower engine then it wont have any airfilter system and you dont want to go there. The main troulbe with these tractors is the base of the orginal engine is small and it has a special aircleaner tube that allows the hood to go down over the engine without hitting it. Another problem is there were all built to use a rope starter and not a recoil like modern engine mostly use. The whole in the hood side is to small for the recoil to fit though, and still be able to close the hood down right. Seem to me that there was once talk of a Honda engine that might fit under the hood and bolt in place. Your orginal one should have had 2 1/2 to 2 3/4 hp, but your might be able to get a 3 to 4hp newer style briggs to fit with the right carb change and going back to a rope starter.
#4 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted January 05, 2012 - 06:02 AM
A later model B&S will bolt on the engine plate without drilling any holes. But you have to remove the hood.
If you do decide to replace the motor with a newer one I would like to buy the old one.
This motor came on a 1978 TroyBilt Pony tiller.
#5 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted January 05, 2012 - 01:36 PM
It can be done because I have bought a few over the years and a one had a 70s briggs 5hp under the hood. They had the recoil on it and the bulky tank/carb setup on it to boot. Of course they had an extra set of holes in the engine plate and slid it all the way back but it worked. NEVER believe it can't be done, people have been doing the impossible for years. All it takes is a good eye for the right engine and a little creativity. If you need ideas just go read some of Ray's (jdcrawler) threads. His projects are way more than a lot of us can accomplish, but the creativity is phenomenal.
#6 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted January 05, 2012 - 08:04 PM
Some of these had HM60 Tecumseh's on them but the Tec motors had a plate that bolted to the bottom of the motor. This motor is on my TroyBilt EconoHorse Tiller, the plate was then bolted to a spacer plate on the motor mount. I believe the bolt pattern on the plate is the same as the B&S motor.
#7 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted January 05, 2012 - 09:02 PM
If your Model 8 looks like this one it's an Early 8 and 2 1/4 hp, if it is a square top it is a Later 8 and 2 1/2 hp.
#8 DanO OFFLINE
DanO
    Greasemonkey
  • 155 Thanks
  • 350 posts
Posted January 06, 2012 - 01:17 PM
"If You Put Your Mind To It, You Can Accomplish Anything."
Dr. Emmit Brown
#9 cid25136 OFFLINE
cid25136
  • 3 posts
Posted January 06, 2012 - 06:39 PM
I would like to thank each and everyone on this site for there incredible and helpful input, lots of great information to take in,,,it seems that the engine part is all taken care of,,,now my next question is getting a cowling for the tractor ,,then modifying it to fit the new engine...My brother-inlaw is very handing with a welding machines and is willing to expand the size of the cowling,,,first things first,,,does anyone have an old cowling for sale? A 57560 David Bradley cowling solid enough to withstanding modification? Please let me know if you have one for sale,,,,thanks again...
#10 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted January 06, 2012 - 07:44 PM
I would be still interested in the old motor.
#11 olcowhand OFFLINE
  • 41,150 Thanks
  • 31,416 posts
Posted January 07, 2012 - 08:29 AM
:bigrofl: Every time I see this thread's title, I see "Hip Replacement"! After both Mom & Dad getting new hips this year, I guess it makes me susceptible! :bigrofl::bigrofl:
#12 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted January 07, 2012 - 08:42 AM
You use your David Bradley for very many years and you need a Hip Replacement. LOL.
#13 BeeMan OFFLINE
BeeMan
  • 1 posts
Posted April 15, 2012 - 02:24 PM
Are you going to sell your original engine? If so, what are you asking?
