David Bradley basket case is here.
19 replies to this topic
#16 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted January 30, 2012 - 02:26 PM
In case you are wondering, if the acquisition of a N, 6, or 8 has the fuel tank mounted on the flywheel cooling showd, the 2 rivets holding on the 2 fuel tank straps to the shrowd can be ground off and the holes left, the raised cast air cleaner tube shown above is another important feature Briggs provided for David Bradley tractors and a model N, 6 or 8 should have the aluminum head and sump.
This looks like a tractor made from several parts judging by the wheel rims, clutch pully, engine mount, kick stand and saddle bar.
You are in good hands, lots of DB collectors here.
#17 steve b OFFLINE
steve b
  • 121 Thanks
  • 220 posts
Posted January 31, 2012 - 08:16 AM
Thanks for the responses! I am going to have to keep my eyes open for a briggs 6 motor and I also need to find some tires and a gas tank as well..
It would be nice to get it running in the spring. I will keep you all posted.
Steve
#18 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted January 31, 2012 - 06:51 PM
When looking for a fuel tank to match a engine best way is to re-use the fuel tank off of the engine it came with, instead of mounting the fuel tank on the engine Briggs and Stratton just sent them to the DB Mfg plant and they mounted it on the tractor, but you have to be carfull, the drain hole on the tank were the sediment bowl screws onto was moved around on different engine and will not work on the DB fuel tank mount, after that then you will just need the tank straps.
#19 mjodrey OFFLINE
  • 2,355 Thanks
Posted February 23, 2012 - 05:18 AM
Thanks for the pics,Steve B.
#20 Texas Deere and Horse ONLINE
  • 14,811 Thanks
  • 15,500 posts
Posted February 24, 2012 - 05:27 PM
Thanks for sharing, that's great info..
  • trowel said thank you
