122 trans problems
12 replies to this topic
#1 mixedbreed96 OFFLINE
mixedbreed96
  • 11 Thanks
  • 167 posts
Posted January 01, 2012 - 08:38 PM
Hey everyone, the 122's 2nd and 3rd gear tend to slip and sound like they are grinding when starting to take off, checked the gears and they look fine and put fresh gear oil in the trans, cant think of anything else that would cause this, also still havnt managed to figure out how my sleeve hitch goes on, really need either detailed instructions or close up pictures of how its installed, thanks in advance! Ryan
#2 olcowhand OFFLINE
  • 40,390 Thanks
  • 31,181 posts
Posted January 01, 2012 - 08:41 PM
Been so long since owning my Cubs that I forget how the axle hubs are....spline or keyed. If spline, you may have an axle or hub stripping itself out.
#3 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted January 01, 2012 - 08:44 PM
You might check the pin in the shaft behind the coupler. These have been known to shear and still pull somewhat.
#4 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted January 01, 2012 - 08:45 PM
Do you have pictures of the sleeve hitch? Also the narrow frame and wide frames use different hitches.
#5 mixedbreed96 OFFLINE
mixedbreed96
  • 11 Thanks
  • 167 posts
Posted January 01, 2012 - 08:48 PM
Cub cadet 3pt looks identical to this
#6 KennyP ONLINE
  • 37,582 Thanks
  • 45,545 posts
Posted January 02, 2012 - 07:20 AM
The install manual can be found here for the WF 3 point;
WF 3 Point Lift Install - Manuals - Garden Tractor Talk - Forums
Cub calls their sleeve hitch a 3 point.
  • mixedbreed96 said thank you
#7 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted January 02, 2012 - 05:11 PM
Here is the install manual for the Narrow frame Sleeve Hitch.
Narrow Frame 3 Pt.
  • jimbobbillyray said thank you
#8 mixedbreed96 OFFLINE
mixedbreed96
  • 11 Thanks
  • 167 posts
Posted January 02, 2012 - 08:05 PM
so now how do i determine whether mine is a narrow or wide frame
#9 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted January 02, 2012 - 08:09 PM
You have a narrow frame. The wide frames didn't start until the 1X8/9 series i.e. 108/128/109/129 etc.
#10 KennyP ONLINE
  • 37,582 Thanks
  • 45,545 posts
Posted January 03, 2012 - 07:34 AM
Amigatec, thanks for reminding me this is a narrow frame. For some reason, I keep thinking anything with a higher # than mine is wide frame. Not so. I'll get it right one of these days. LOL
#11 Kyocum OFFLINE
Kyocum
  • 299 Thanks
  • 424 posts
Posted January 03, 2012 - 10:10 AM
Check your teaser spring behind the clutch plate and all the coiled spring pins on the driveshaft. Sounds to me like on of the pins is broke. Chances are the pin that the sliding clutch plate rides on is broken.
#12 ad356 OFFLINE
ad356
  • 9 Thanks
  • 160 posts
Posted January 08, 2012 - 06:12 AM
i believe that if something is wrong with the clutch the pedal wont disengage the power to the transmission like its supposed to. in other words if its grinding while already in a gear then its something else. i worked on a quiet-line once that would not stop when you pushed in the clutch pedal. the throw-out bearing had failed.
#13 Randy Littrell OFFLINE
Randy Littrell
  • 2 Thanks
  • 2 posts
Posted January 09, 2012 - 09:03 AM
Its in the clutch. Best bet is to pull it out and go through it. If you do it right you wont have to worry about it for another 20 years!
More than likely you need a clutch disc, teaser spring, clutch spring and get your plates turned or replaced. Oh and throwout bearing is probably shot as well.
There are plenty of places to get a manual online for free if you don't have one.
Check out this link for help as well. Improving the Drive Clutch Assembly in a Cub Cadet
Randy
