New To Me Allis 620
157 replies to this topic
#61 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted January 07, 2012 - 04:19 PM
Dan what does it weigh and what size are the rear tires ?
#62 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted January 07, 2012 - 06:03 PM
Tires are 31x15.5/15. Tractor alone weighs 1300, and the 50" deck adds a whopping additional 282lbs.
#63 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted January 07, 2012 - 06:10 PM
Been working on this 620 most of the day. Got a lot of little things done. Mechanical fuel pump installed, choke cable installed, carb heat shield installed, brakes adjusted, among other little bits. Also wire welded the thin heat shield back to the muffler, and filled in a hole punched into the muffler. Had a fun day!
The tank still has to be repaired, plus a big job when I get to it....the right brake hardly works at all, and is a BIG job getting at it as they are behind the drop axles, up against the tranny housing. That will be a job when winter turns cold.....maybe.
#64 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted January 08, 2012 - 08:02 AM
That's probably the heaviest GT that I've ever seen. You could almost call it a compact tractor rather than a GT. It would make a good loader tractor with PS!
#65 MH81 OFFLINE
Posted January 08, 2012 - 08:36 AM
Daniel, are you trying to scare the green machines next door again? You keep bringing home tractors like that, your BIL will have a hard time keeping up with the "brown spots" in his yard when his tractors see them...
#66 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted January 08, 2012 - 10:12 AM
Those 430's have nothing to fear....they are powerhouses! But I think Fred is a bit intimidated! LOL
#67 Bill56 OFFLINE
  • 839 Thanks
  • 2,179 posts
Posted January 08, 2012 - 10:35 AM
What a great tractor, Daniel! They don't make them look any better than that!!!
#68 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted January 08, 2012 - 01:28 PM
Thanks everyone for the compliments. I tell you one thing, these aren't the easiest to work on. Things are tight & in the way of everything else you need to do. I finally got the rear pto shaft & clutch back in this morning. I will run static tests on the regulator & rectifier if I have time before afternoon chores.
#69 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted January 08, 2012 - 01:58 PM
Daniel, about the fuel pumps. All modern electronic components that are designed for use in automotive 12v systems should be able to withstand the alternator spikes which can be 60v or more. These pulses are very short in duration and are hard to measure accurately on a typical DVM. Who knows if the suspect fuel pumps were built to those standards but my gut feeling is that 17v would not destroy the electronic parts. However if a prolonged 17v was placed on them the pump might draw enough current to damage the parts or the pump solenoid itself. If you have a bad ground then that may be causing problems with the pumps as well. Let us know what you find.
#70 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted January 08, 2012 - 03:56 PM
As I read my meter, both the rectifier & regulator are bad. I'm gonna have Fred run the tests with his meter, plus he's more versed on this kind of electronic testing.
#71 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted January 09, 2012 - 09:02 AM
Nice look GT Daniel, I knew those were big GT's but they are even bigger after seeing you driving it.
#72 Texas Deere and Horse OFFLINE
  • 14,800 Thanks
  • 15,495 posts
Posted January 09, 2012 - 03:12 PM
Daniel, That is a great looking 620. Glad you are getting all the bugs worked out of her.
#73 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted January 09, 2012 - 07:20 PM
Fred double checked my readings, and it's confirmed, both regulator & rectifier are bad. I'll static test the stator asap, and if it's bad, I'll fit a small alternator onto it. If stator is good, I may save up for the 2 new electronics, but at $150 + shipping, that will be a while.
#74 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted January 09, 2012 - 09:06 PM
What happens with a standard rectifier
#75 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted January 09, 2012 - 09:47 PM
I don't have a stand alone rectifier, but a std Onan 3 spade regulator/rectifier doesn't put out any DC, even though both stator AC lines are putting out 17VAC each, which is the perfect voltage. Not sure why, just doesn't work.
