3-pt Disk Project
11 replies to this topic
#1 grnspot110 ONLINE
grnspot110
  • 4,147 Thanks
  • 2,640 posts
Posted December 30, 2011 - 06:06 PM
I've been working on a cheap off-set disk project for the last couple of days;
I started out with the back half of an old JD tandem drag disk that I bought for $50, add a couple of 5/8" x 4' rods for the rear support braces ($13) & a few 1/2" grade 8 bolts from my bolt bin. Still need to cut the rounded ends from the front gangs & weld them to this one, switch some blades with the front as it has set in the ground too long & give it some paint next Spring. I should just cut out the tracks of my 790.
May not be the best disk around, but I just can't justify the cost of buying one for no more than I'll use it! ~~ grnspot
#2 MH81 OFFLINE
Posted December 30, 2011 - 06:44 PM
Look like you'll have a nice solid set of discs when you're done. Good plan on using what you've got, the new ones wouldn't be built that well anyways.
#3 KennyP ONLINE
  • 38,222 Thanks
  • 45,860 posts
Posted December 30, 2011 - 06:51 PM
Ought to do the job. Great ingenuity and saved a bunch of cash.
#4 massey driver ONLINE
massey driver
  • 1,422 Thanks
  • 1,576 posts
Posted December 30, 2011 - 07:42 PM
Always nice to beable to recycle the older stuff and make it work again for our needs.Looks good and the price is right.Larry
#5 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted December 30, 2011 - 09:02 PM
looks like a great little disc im sure it will disc just like a new one would .
#6 tractormike OFFLINE
tractormike
  • 167 Thanks
  • 1,488 posts
Posted February 16, 2012 - 07:00 AM
That is a very nice job making something usefull from what you have laying around! Your disc looks like it should do a fine job.Post some pictures of you getting it dirty this spring if you can.
#7 daytime dave OFFLINE
  • 4,833 Thanks
  • 6,539 posts
Posted February 16, 2012 - 12:16 PM
I agree. Very nice work using what you have.
#8 mjodrey OFFLINE
Posted February 19, 2012 - 06:49 AM
:ditto:
#9 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted February 19, 2012 - 12:29 PM
grnspot, Looks like you will have a nice disk to use. We will love to see the picts. of it working. Shawn
#10 Goltz OFFLINE
Goltz
  • 2 Thanks
  • 11 posts
Posted March 16, 2012 - 01:33 PM
i am sorry, mens!
#11 HowardsMF155 ONLINE
  • 2,861 Thanks
  • 2,987 posts
Posted March 16, 2012 - 09:50 PM
Nice work! I hope to do something similar with a couple of Brinly discs. How did you decide on your offset angle? Did you set up the rear disc to "slide" side to side so you can dial in how the discs react from front to back?
#12 grnspot110 ONLINE
grnspot110
  • 4,147 Thanks
  • 2,640 posts
Posted March 17, 2012 - 06:13 AM
Thanks! I set the angle according to a "working" disk. The gangs are bolted solid, two 1/2", grade 8 bolts in each end of each gang. ~~ Lowell
  • HowardsMF155 said thank you
