To start building the hoophouse, we selected the place for the it to maximize sun on the hoophouse and the keep it away from trees which might drop a branch and damage the plastic.
So with the location selected and it measured out with stakes and string we put up the first hoop to see how it was gonna work.
Once we had it figured out Dad started framing out the end in that first hoop.
Then we drove sections of 1 3/4 inch (about 4.5 cm) in the ground for the legs of the hoops made of 1 3/8 inch (about 3.5 cm) to slip into.
While the layout was figured out and the small pipes were being cut and driven into the ground some of the guys were bending the hoops out of two sections of pipe which fit together at the ends. Unfortunately there were no pictures taken of the pipe bending jig but I tried to describe it here.
TractorByNet.com - View Single Post - Frost has killed my garden
Once all the short larger pipes were driven into the ground it was simple and easy to grab a hoop and insert each end into the pipes and then repeat with the next one.
Once enough of the hoops were installed some guys started working on the bracing down the ridge.
Once the all the hoops were completed the other end wall was built with a single door and framing for a vent in the future.
I think that was it for the first day.
The following day we did much of the bracing and plywooded the end wall.
We attached 2x4's along the first bend on the walls (see left wall in above picture) to attach the plastic to and for a solid attachment when we made the sides roll-up-able at a later date.
This was our completed hoophouse before the plastic was put up.
Here is what the completed hoophouse looked like when we put the compost in, right after planting, as it grew, and finally the jungle later in the summer.
Here is the exterior in the summer and the rock pile. We installed roll up side two years ago and these pictures are from the same year.
It is still going pretty well. We get a little vandalism but not too much to deal with. We want to install drip irrigation to save on watering labor and we want to figure out a way to make the hoophouse portable. Put it on skids or something. Rains and snow do a lot for the soil and when it all has to be done by hand, it get's pretty tiring. We set up a rainwater collecting system to save on the water bill. I can post some about that when I get the time. My mom has a blog on the garden at this link.
Wilson Street Urban Farm
If you all want more pictures of a certain part let me know and I'll see if we got any. I'll also try to post a picture of our compost and manure pile we have out there right now waiting to be spread in the appropriate places while I wish for a front end loader:D.
Edited by Lovintractorin, December 31, 2011 - 07:25 AM.
