Voltage Regulators for S/G Systems
3 replies to this topic
#1 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted December 29, 2011 - 08:02 PM
This is something I've wanted to post here for some time. We seem to have a few questions on Voltage regulator for Starter/Generator Systems.
First there are at least different types of VR for these systems.
I will name these Type A, B, and C.
Here are Type A and Type B
Notice where the rear Terminals are.
Type A is on the RIGHT Rear Corner.
Type B is on the LEFT Rear Corner.
This is important.
The Rear Terminal on Type A is marked GRD and is for Grounding the VR.
The Rear Ternimal on Type B is marked G and is for the GEN Connection.
Type A front Terminals are marked BAT, GEN, FLD.
Type B front Terminals are marked L, BAT, FLD.
The BAT Terminal goes to the Battery, the GEN Terminal goes to the G post on the S/G, the FLD Terminal goes to the F post on the S/G, and the L Terminal goes to Load.
Your Tractor may or may not use the L Terminal.
Type C has the same connections on the front but the GEN Terminal is on the Bottom.
My Cub Cadet 129 was originally equipped with the Type A VR, but I am using the Type B instead.
Notice how I am not using the L Terminal and have connected the GEN to the rear Terminal.
I hope this helps somebody. All 3 of these will work but they have to be wired correctly.
  • mikebramel, MH81, Alc and 6 others have said thanks
#2 MH81 OFFLINE
Posted December 29, 2011 - 09:35 PM
I'm going to study this more and bookmark the page. That's right dandy info. Thanks.
#3 KennyP ONLINE
  • 38,377 Thanks
  • 45,933 posts
Posted December 30, 2011 - 03:38 AM
That could clear up some folks confusion.
#4 Michiganmobileman OFFLINE
Posted December 31, 2011 - 08:21 AM
Thanks for the info, you may have just prevented someone from installing one of these wrong and letting the smoke out of it!!:thumbs:
Edited by Michiganmobileman, December 31, 2011 - 08:22 AM.
Rephrase
