Square fender Case is a great place to rest my coffee cup
32 replies to this topic
#1 markdombroski OFFLINE
markdombroski
  • 196 Thanks
  • 432 posts
Posted December 27, 2011 - 11:23 AM
[ATTACH]27132[/ATTACH]
I am getting ready to work on the Case 446 this morning and the first thing I saw was that the square fender was a perfect perch for my coffee mug.
Yesterday I washed the tractor, changed the engine oil, charged the battery, cleaned the spark plugs, replaced some bad/incorrect wiring (It seems that every old garden tractor I get has hacked wiring). I also drained the fuel lines and cleaned the dirt encrusted outer side of the carburetor. Now it turns over. I think that I need to take a look at the ignition system next and verify spark to the plugs. I think there are points on this Onan engine. I learned something, be careful when you remove the air cleaner housing from the carburetor. The mounting screws can fall into the carburetor and into the intake manifold. Fortunately, I was able to fish the screw out with long pair of needle nose pliers. :madhop:
Edited by markdombroski, December 27, 2011 - 11:31 AM.
#2 tinner OFFLINE
tinner
  • 503 Thanks
  • 1,561 posts
Posted December 27, 2011 - 11:55 AM
Sounds like fun, my brother has a Case with the hydraulic tiller and it looks like one heck of a tractor. I know what you mean abut little screws falling, seems like every time I do something my old fingers will drop something and it always winds up somewhere like in the carburetor if working there or in some hard to get to place. Glad I have a magnet on a stick and long needle nose pliers. Good luck on starting the ole babe up.
#3 markdombroski OFFLINE
markdombroski
  • 196 Thanks
  • 432 posts
Posted December 27, 2011 - 12:00 PM
Thank you Tinner, I think she will run, just needs some care. I am no real mechanic, so I learn as I go. Definite fun!
Edited by markdombroski, January 02, 2012 - 10:49 AM.
#4 markdombroski OFFLINE
markdombroski
  • 196 Thanks
  • 432 posts
Posted December 27, 2011 - 12:06 PM
Ok, I verified there is no spark on the plug. The points and ignition seem a bit corroded. I will replace the points and condenser, but will try to work with the old ones first.
[ATTACH]27133[/ATTACH]
Edited by markdombroski, December 27, 2011 - 04:41 PM.
#5 olcowhand ONLINE
  • 43,182 Thanks
  • 32,014 posts
Posted December 27, 2011 - 12:12 PM
Just about the worst set of contacts I've seen! That carb is a Marvel Shreiber DD model. They can be a bit testy, but first get the spark. Maybe you'll get lucky on the carb & she'll run right away.
#6 markdombroski OFFLINE
markdombroski
  • 196 Thanks
  • 432 posts
Posted December 27, 2011 - 01:01 PM
Cleaned up the points and she runs. The engine speed tends to wander a bit, but not bad for first run.
[ATTACH]27134[/ATTACH]
[ATTACH]27137[/ATTACH]
[ATTACH]27138[/ATTACH]
  • gopher said thank you
#7 MH81 OFFLINE
  • 29,979 Thanks
Posted December 27, 2011 - 02:11 PM
Glad to hear you got it running, sounds pretty good.
As for the "Wandering" you hear brand new engines do that much sometimes :D
Might want to run a little seafoam thru it... can't hurt.
#8 NUTNDUN OFFLINE
  • 10,354 Thanks
Posted December 27, 2011 - 03:44 PM
Didn't take ya long to get her running. The Onan in my Massey 1655 likes to wonder at idle sometimes. I have tried adjusting the carb and rebuilt it and it still does it, so I just wrote it off as nature of the beast.
#9 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted December 27, 2011 - 04:00 PM
nice tractor you have there, glad you got it running without to much trouble. whats that whining noise?
#10 markdombroski OFFLINE
markdombroski
  • 196 Thanks
  • 432 posts
Posted December 27, 2011 - 04:28 PM
I think the whining is the hydraulic pump. I think this is the way it is supposed to sound.
#11 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted December 27, 2011 - 05:24 PM
Square fender Case tractors are great for setting a lot of things on, not only just the fenders... just take a look at my Case 222 sometime, if you can find it under all the stuff I set on it LOL.
  • markdombroski said thank you
#12 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted December 27, 2011 - 05:49 PM
i was wondering if it was the pump, never had a hydro drive so i thought i would bring it up to be sure. i put things on my tractors all the time... just dont scratch the paint.
#13 KennyP ONLINE
  • 41,527 Thanks
  • 47,427 posts
Posted December 27, 2011 - 07:01 PM
Mark, sounds great. I'd try the seafoam before doing a lot of tuning. That seems to help sometimes. I love those Onans.
#14 markdombroski OFFLINE
markdombroski
  • 196 Thanks
  • 432 posts
Posted December 27, 2011 - 08:30 PM
No need about scratching the paint on this one. I spent some time today buffing with rubbing compound. Makes the paint shiny, but also you can see the rust spots and scratches more.
#15 markdombroski OFFLINE
markdombroski
  • 196 Thanks
  • 432 posts
Posted December 27, 2011 - 08:32 PM
I have heard about Seafoam but have never used it. I did put a small amount of Marvel Mystery oil in the gas and oil. How do you treat the engine with Seafoam?
