Case 446 transplant
31 replies to this topic
#31 Utah Smitty OFFLINE
Utah Smitty
  • 1,702 Thanks
  • 1,781 posts
Posted June 23, 2012 - 12:22 AM
If a person could get reamers with the right diameter and taper, it would be easy to ream the hole of a LoveJoy coupler, etc.
I know of a man that used to make his own chambering reamers for firearms using this method:
Get a piece of hardenable steel and turn to the desired taper.
Carefully grind off one half of the piece so you have the desired taper in profile. If you do it carefully enough, the flat side where it was ground off will act as a cutting edge and could be used (with plenty of oil) to put a taper into a straight hole.
Another possibility would be to get an old tap of the right diameter and grind a taper into it... the flutes would tend to act as cutting edges...
#32 Boss 448 OFFLINE
Boss 448
  • 48 Thanks
  • 248 posts
Posted July 26, 2013 - 04:23 PM
Been a long time since I visited this thread. If Bulldogbones is still out there how about an update on this project. Case Ingersoll fans (like my self) would like to see the end results and hear your assement regarding the performance of your project.
