* * * - - 2 votes
MF Belt Cross Ref. Webpage
34 replies to this topic
#16 tjbindy OFFLINE
tjbindy
  • 86 Thanks
  • 61 posts
Posted June 10, 2015 - 06:17 PM
Looks like the cross reference for the Deck Blade Timing Belt for a 48 inch deck on the MF1450 is incorrect.  The gates number listed is 6385.  The width on a 6385 belt is only about half the width of the correct belt.
Edited by tjbindy, June 10, 2015 - 06:27 PM.
#17 Bolens 1000 ONLINE
  • 17291 Thanks
  • 18793 posts
Posted June 10, 2015 - 06:26 PM
Looks like the cross reference for the Deck Blade Timing Belt for a 48 inch deck on the MF1450 is incorrect.  The gates number listed is 6385.  The width on a 6385 belt is only about 20% as wide as the correct belt.
Thats the problem with using Auto stores and Gates cross referencing, its usually a crap shoot and they just list the closest size which may be the wrong width and length.
To be accurate you need to either get a genuine replacement or use an actual Lawn and Garden cross .
Do you have the part number for the belt you need I may be able to help you out get the right one or point you to someone who can
#18 tjbindy OFFLINE
tjbindy
  • 86 Thanks
  • 61 posts
Posted June 10, 2015 - 11:37 PM
I actually found a set on e-bay that has the massey ferguson number.  Just waiting on a quote for combined shipping.
#19 olcowhand OFFLINE
  • 44095 Thanks
  • 32301 posts
Posted June 11, 2015 - 10:40 AM
I also found some with the Massey OE number that had a 36" length.
#20 MFDAC OFFLINE
MFDAC
  • 3699 Thanks
  • 1769 posts
Posted June 22, 2015 - 06:31 PM
Thanks MAC, got 2 numbers for a front Vari-drive belt for my MF12G from your site. Now it's time to search to buy!
DAC
  • mac102004 said thank you
#21 ducky OFFLINE
  • 2311 Thanks
  • 4299 posts
Posted April 02, 2016 - 10:22 AM
Massey 14 16 tiller belt. 1043214M1 = A175
  • limebuzz said thank you
#22 LovemAll OFFLINE
LovemAll
  • 2 Thanks
  • 1 posts
Posted June 13, 2016 - 03:15 AM
That chart just saved my butt!  I measured my broken belt at 45" and the closest thing I found on the internet was 44" which I ordered from Gates.  Wrong!  When I found the chart I clicked the link to AI and found out there really is a 45".  Had to cancel the other order.  Thanks for the info!
  • mac102004 and MFDAC have said thanks
#23 mac102004 OFFLINE
mac102004
  • 596 Thanks
  • 610 posts
Posted June 16, 2016 - 08:59 AM
Thanks guys, did some updates. If anyone as anymore numbers or any other info feel free to PM me and I'll add it to the page.
  • MH81 and Dugmf12 have said thanks
#24 MFDAC OFFLINE
MFDAC
  • 3699 Thanks
  • 1769 posts
Posted August 26, 2016 - 08:59 PM
I don't know if this will be of use but I have a couple of A&I belt numbers. I needed the pto drive belt for my MF12G with the Predator engine conversion as I had been running one an inch to long and it slipped now and then mowing. All I found locally at a reasonable price were in 2" even numbered increments. This conversion uses a 31" belt best. 30" belt would not let the cutting deck disengage. I also needed the pto to deck drive 50" belt so I ordered both from V-Belt supply in Sioux Falls, SD. $22 shipped for both belts.
13 HP Predator engine conversion PTO drive belt #A29K, 31" belt.
PTO to mower deck drive belt #A48K, 50" belt that fits 1975 MF12G
DAC
  • olcowhand, limebuzz, MH81 and 1 other said thanks
#25 mac102004 OFFLINE
mac102004
  • 596 Thanks
  • 610 posts
Posted August 29, 2016 - 11:25 AM
DAC
Thanks, I'll try and add that in the next update.
  • ducky, MH81 and MFDAC have said thanks
#26 ckjakline OFFLINE
ckjakline
  • 1181 Thanks
  • 1173 posts
Posted January 01, 2017 - 10:47 AM
Not sure if anyone else had this issue or not but the loader tractor i just got had a&i belts on it with same part number as the actual massey. clutch wouldn't depress the whole way and tractor wouldn't stop. Put massey belts on off another tractor and problem solved. The a&i belts were too short.
  • ducky and limebuzz have said thanks
#27 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted January 01, 2017 - 01:03 PM
What is the number for the 2 little belts that are on the 16 and 1855? The 2 that mate the driveshaft to the rear PTO.i thought I read somewhere they were an a20 or similar.thanks.
#28 ducky OFFLINE
  • 2311 Thanks
  • 4299 posts
Posted January 01, 2017 - 02:08 PM
I think you are right. I have a set out in the shop and will get you measurements later to day.
#29 ducky OFFLINE
  • 2311 Thanks
  • 4299 posts
Posted January 01, 2017 - 03:07 PM
Agco Parts give me Pt # 3021289M91 here. Use the Guest View to get to the Parts Book
That crosses to an A30 (1/2 x 32).
Seems to be a bit long to me but will double check when I get out to the shop.
Edited by ducky, January 01, 2017 - 03:25 PM.
#30 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted January 01, 2017 - 03:49 PM
Thanks Ducky,30's sound way too long for in there.
