Video clip of 1967 2412 Powerking Transmission Operation
11 replies to this topic
#1 fort apache OFFLINE
fort apache
  • 15 Thanks
  • 137 posts
Posted December 23, 2011 - 02:39 PM
Thanks a lot guys for the info in the thread about taking out the transmission.:smile1: I have a short video clip of my tractor goint through the gears. The audio is not that great, but its close. Please watch it and let me know what you think.
#2 Ryan313 OFFLINE
  • 3,240 Thanks
  • 5,159 posts
Posted December 23, 2011 - 03:10 PM
yep, bearings will get rid of most if not all of the noise. they do make some noise but if they have good bearings you cant really hear it unless you listen for it.
  • fort apache said thank you
#3 fort apache OFFLINE
fort apache
  • 15 Thanks
  • 137 posts
Posted December 23, 2011 - 04:15 PM
To me, it seems just a little too loud. I don't know if I'm just too particular. Sometimes I got to step back and see if its just me looking to deep.
#4 Ryan313 OFFLINE
  • 3,240 Thanks
  • 5,159 posts
Posted December 23, 2011 - 05:02 PM
it is a little loud, when you take off the cover you will know for sure.
#5 Alc ONLINE
  • 5,808 Thanks
  • 6,818 posts
Posted December 23, 2011 - 05:58 PM
I'm sure your going to replace all the bearings but looking at the trans part's list it looks like when your in 3rd gear the input and output shafts are locked together , so guessing that why it's not as noisy in 3rd Those wouldn't be spinning in 3rd. The roller bearings item #31 could be bad , give them a good check , AlDSC07871.jpg
#6 Ryan313 OFFLINE
  • 3,240 Thanks
  • 5,159 posts
Posted December 23, 2011 - 06:10 PM
I'm sure your going to replace all the bearings but looking at the trans part's list it looks like when your in 3rd gear the input and output shafts are locked together , so guessing that why it's not as noisy in 3rd Those wouldn't be spinning in 3rd. The roller bearings item #31 could be bad , give them a good check , Al[ATTACH=CONFIG]26921[/ATTACH]
3rd gear is a 1:1 ratio.
#7 Alc ONLINE
  • 5,808 Thanks
  • 6,818 posts
Posted December 23, 2011 - 06:27 PM
Correct , that's why the roller bearings supporting the input and output shafts will not be turning in 3rd , any other gear or neutral those shafts will be spinning at different speeds or reverse . Al
#8 fort apache OFFLINE
fort apache
  • 15 Thanks
  • 137 posts
Posted December 23, 2011 - 06:58 PM
I will check them out. I just want to double check with you guys. When I inspect the bearings there should be:
No play whatsoever -- correct?
I didn't get to it today. I'll do it tomorrow of monday.
#9 Ryan313 OFFLINE
  • 3,240 Thanks
  • 5,159 posts
Posted December 23, 2011 - 07:26 PM
yes no play. look at the pic below, the shaft on the top is what will be moving, put a screwdriver on it and gently push it, you will be able to tell if it moves.
#10 Alc ONLINE
  • 5,808 Thanks
  • 6,818 posts
Posted December 23, 2011 - 07:44 PM
Took a few pictures for you , here's the input shaft ,output shaft and 2 of the 13 roller bearings DSC07873.jpg
#11 fort apache OFFLINE
fort apache
  • 15 Thanks
  • 137 posts
Posted December 25, 2011 - 06:29 PM
I feel like a deadbeat here because all I do is take you gentlemans' advice. I got nothing in return but my thanks. Very helpfull.
#12 Ryan313 OFFLINE
  • 3,240 Thanks
  • 5,159 posts
Posted December 25, 2011 - 08:07 PM
You are vey welcome. youll learn fast, I just started learning more about power kings this summer. in a few months you will know that tractor inside and out. You may not think your doing anything, but you are. Since you have gotten your pk I have acctully learned a few things myself. So, thanks YOU!
