My Cub 109
54 replies to this topic
#31 olcowhand OFFLINE
  • 42,896 Thanks
  • 31,939 posts
Posted January 29, 2012 - 08:45 PM
All,
Ive been looking at small single cylinder diesel engines as a possible replacement for the K241. If I stick to the same HP rating do you think the Hydro would be ok??
You would as already said be fine with a much larger engine, diesel or gas. That hydro is capable of handling much more HP than it has now. Basically it's the same hydro as in my JD F935 with 22hp diesel Yanmar.
#32 olcowhand OFFLINE
  • 42,896 Thanks
  • 31,939 posts
Posted January 29, 2012 - 08:46 PM
Also here are a couple more pics. Lemme know when you guys get sick of them.
Just seen this post.........and you must be joking.......we NEVER tire of pics!
#33 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted January 29, 2012 - 09:41 PM
I just stumbled on this thread and your deffintly doing a great job on it! I can't wait to see how the black comes out, I was thinking about what that would look like the other day.
#34 cantgetitright OFFLINE
cantgetitright
  • 2 Thanks
  • 32 posts
Posted January 30, 2012 - 08:48 AM
Thank you Ryan. The flat black is really standing out. Flat black, flat white, and glossy yellow. Weird combo but it looks hot (for a garden tractor). :smile1: Oh yeah and a bit of green.:D
#35 Saltydawg OFFLINE
Saltydawg
  • 3 Thanks
  • 34 posts
Posted January 30, 2012 - 11:31 AM
All dressed up and no where to go! LOL Looking good. Time to put it to work now!
P.S. Don't feel bad when you put the first scratch on it, these old timers were meant to work.
#36 cantgetitright OFFLINE
cantgetitright
  • 2 Thanks
  • 32 posts
Posted February 02, 2012 - 06:56 AM
Thank You Saltydawg. I cant wait to scratch it and push some snow but.........
Alright all you tractor gurus out there I need a bit of help. Got her all back together (looks very nice btw.) and the damn thing wont run. It wont even offer to run. Best I can come up with is when I changed the points and push rod that I screwed up the timing. I think its trying to fire with the valve still open cuz its burping back through the carb. Any suggestions?? Oh yeah, it has Spark and is getting fuel. :wallbanging:
#37 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted February 02, 2012 - 07:03 AM
how did you time the motor?
#38 cantgetitright OFFLINE
cantgetitright
  • 2 Thanks
  • 32 posts
Posted February 02, 2012 - 07:29 AM
I guess I didnt. I just assumed that since it was running fine before I changed the points if I put them back the same way I wouldnt have to. Guess I was wrong. Ive never timed an engine before. I read up on timing the motor last night and I think ill do it with my multimeter set on resistance. If I read correctly just connect the probes to the points and the second theres any change in resistance that means the points are open and sp or s should be showing in the timing window. This makes it 20 degrees before tdc correct? TDC being where the piston is at its highest part of the stroke? Im having a little trouble finding the timing window. Its kinda by the starter generator on the main engine shroud right?
#39 cantgetitright OFFLINE
cantgetitright
  • 2 Thanks
  • 32 posts
Posted February 02, 2012 - 07:30 AM
Thank you Amigatec for the prompt response btw.
#40 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted February 02, 2012 - 08:28 AM
On the right side of the tractor their should be a small round hole, look inside that hole you should see a mark you may have 2 marks, my 12 hp does, I don't remember which mark to use, but line up the coprrect mark with the line on the outside. On my 14 hp kohler it lookls like this.
Make sure the switch is off, and aqdjust the points so the meter shows 0 ohms when they open.
You should be ok then.
#41 KennyP ONLINE
  • 40,879 Thanks
  • 47,091 posts
Posted February 02, 2012 - 08:46 AM
Reading this made me look for a file I have that wasn't in our manuals. I just uploaded it here: K-Series Static Timing - Manuals - Garden Tractor Talk - Forums
Hope it helps.
  • cantgetitright said thank you
#42 IHCubGuy OFFLINE
IHCubGuy
  • 1,611 Thanks
  • 1,638 posts
Posted February 02, 2012 - 08:54 PM
They can be a real bear if the points aren't just right on them. When I first got my 107 from my buddy it started ok but it always labored REAL hard for the first 10-15 minutes of using it and it lacked power. When it would warm up it ran fine. It had been recently rebuilt and I chased it down thru the carb and fuel issues until someone pointed me in the direction of checking that the points were set right. They were WAYYYY off! After setting them right its like a whole different machine.
#43 cantgetitright OFFLINE
cantgetitright
  • 2 Thanks
  • 32 posts
Posted February 03, 2012 - 12:29 AM
Thanks guys for all your help. I still need to time it but figgered i would show you some pics of it 98% done. Just need to touch up the paint and set the timing and shes complete. Lemme know what you all think!!
#44 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted February 03, 2012 - 07:01 AM
Looks good! I like your paint choosings.
#45 KennyP ONLINE
  • 40,879 Thanks
  • 47,091 posts
Posted February 03, 2012 - 07:05 AM
You did a good job with it. Looks a lot better.
