Sleeve hitch for the Cub 100
3 replies to this topic
#1 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,787 Thanks
  • 2,753 posts
Posted December 23, 2011 - 12:35 AM
Got started last weekend on the sleeve hitch project for my cub 100. Got some cutting, bending, welding done. Used the hitch plate from the Cub as a model...locked it in my vise, heated it and bent around the hitch plate to make sure it fit the plate. I don't know for sure if it will be strong enough, but thought I would give it a try. The main frame is 2 1/4 x 1/4 bar stock. I will get some more pics up when I work on it again.
#2 MH81 OFFLINE
Posted December 23, 2011 - 01:27 AM
Nice sleeve hitch in the making. The ones you see online often have several cross braces in them, are you planning on some sort of bracing on yours?
#3 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted December 23, 2011 - 01:38 AM
Great start to a sleeve hitch, hope you add some gussets to make it substantial enough to take side loads.
#4 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,787 Thanks
  • 2,753 posts
Posted December 23, 2011 - 02:43 AM
yep. got that going on. will take some more pics when I work on it again.
