Mf 1655 problem
27 replies to this topic
#16 Enginerod OFFLINE
Enginerod
  • 251 Thanks
  • 299 posts
Posted February 26, 2012 - 08:58 AM
Like MH81 said, he may have put 90 weight in there. I would think that could possibly make the belts slip just by putting so much stress on the pump trying to pump it.
#17 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted February 26, 2012 - 09:01 AM
Massey 14/16 manual does state a Massey oil specific for the Sundstrand... M1110 But yes, if by some miracle he pumped 80/90 in there, now that would change things!
#18 whitelt120 OFFLINE
whitelt120
  • 17 Thanks
  • 119 posts
Posted February 26, 2012 - 05:58 PM
imageCANZAR6A.jpg I believe this is the stuff we used. I have some more questions
1. Where is the best place to get an oil filter for an onan b43m engine?
2. How do I remove the belts that are connected to the pto shaft and the driveshaft behind the engine?
Edited by whitelt120, February 26, 2012 - 06:00 PM.
#19 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted February 26, 2012 - 06:17 PM
You can download the service manual here for the belt instructions (2 parts):
http://gardentractor...ice-manual-pt1/
http://gardentractor...ice-manual-pt2/
I can't remember the oil filter #'s, but will look them up. I either use WIX or Phram oil filters. That oil pictured should not be too thick, but I'd switch back to Dexron III.
  • whitelt120 said thank you
#20 whitelt120 OFFLINE
whitelt120
  • 17 Thanks
  • 119 posts
Posted February 26, 2012 - 06:42 PM
I picked up my oil and filter yesterday and i plan to change it soon.
But i need help woith this too. I have no idea what this is and how it works.
#21 massey driver OFFLINE
massey driver
  • 1549 Thanks
  • 1613 posts
Posted February 26, 2012 - 09:24 PM
Thats your belt tensioner bolt it should have a washer and nut on the end thats showing none in your pic.Here;s a pic of mine from underneath my tractor.Just remeber mine has been relocated to a different spot but it will still show you how the spring and nuts are set up.I relocated my complete tensioner assembly and have mounted it onto the tractor frame rather then mounted onto the rubber mounted motor frame.I did this to stop the drive shaft from walking around and wearing out the splinned yoke and shaft that go into/onto the hydro.By doing this mod the belts do the flexing now rather then the whole drive shaft constantly moving. One thing to add is that my manual says that the spring should be tightened up so that the spring ends up being 1 1/4" long when set properly.Larry
Edited by massey driver, February 26, 2012 - 09:49 PM.
#22 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted February 26, 2012 - 09:35 PM
Looking at the pics of the belts, I see 2 issues. One is that they are 2 different make belts. They need to be a matched pair. Belts can vary enough that they fit the pulleys a tad different, or stretch differently. One of these belts is not as tight as the other, & neither appear tight enough. The last pic is the one that appears to show the belts aren't tight, especially the one marked "India".
#23 coldone OFFLINE
coldone
  • 1716 Thanks
  • 1709 posts
Posted February 26, 2012 - 10:08 PM
I fought with wrong belts for a while with my 1855. Spend the money and get the correct belts and tighten them properly. The adjuster is going to push downward on the bottom pulleys. You will want to turn the nut at the bottom of the spring CCW to tighten against the spring and the spring will compress against the motor mounting frame. Once you get this done correctly you will not have to worry about it for a very long time.
Here is a link to partstree.com page for the belts. Snapper part number is 7019550.
http://www.partstree...or (MF)&dn=5667
Edited by coldone, February 26, 2012 - 10:14 PM.
  • TheFarm2004 and whitelt120 have said thanks
#24 whitelt120 OFFLINE
whitelt120
  • 17 Thanks
  • 119 posts
Posted February 26, 2012 - 10:44 PM
Thanks for all the help! If I wasn t for you guys I would have made no progress! Thanks a ton!
#25 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted February 26, 2012 - 10:49 PM
That's why we're here, and to learn more ourselves!
#26 HowardsMF155 OFFLINE
  • 3079 Thanks
  • 3084 posts
Posted February 27, 2012 - 07:44 AM
Way to go guys!
#27 TUDOR OFFLINE
TUDOR
  • 573 Thanks
  • 507 posts
Posted February 27, 2012 - 11:29 AM
Note: Without the top nut and washer to act as a jam nut, the whole thing will loosen off from vibration and you'll be back to square one again.
#28 whitelt120 OFFLINE
whitelt120
  • 17 Thanks
  • 119 posts
Posted February 27, 2012 - 08:01 PM
Tonight after school I changed both the engine and tranny fluid. It moves alot better now, but I still have to work with the belt tensioner and get the new belts. I noticed tonight tho that my rear housing where the 3 point connects has cracked so I will have to get that welded for sure.
