Olympic Gear transmission parts
19 replies to this topic
#16 Alc ONLINE
  • 6,912 Thanks
  • 7,472 posts
Posted December 23, 2011 - 08:25 PM
Or if the bushing that holds the other end of the input shaft in the flywheel was worn allowing the input shaft to wobble a little.
Something to check then,, next time it's apart, thanks , Al
#17 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted December 23, 2011 - 08:36 PM
:ditto: My splines were very worn but still usable until the clutch went shortly after I checked them.
I've seen that happen to big trucks, it's normally caused by lots of miles running down the road.
#18 Lovintractorin OFFLINE
Lovintractorin
    Tinkerer
  • 159 Thanks
  • 603 posts
Posted December 23, 2011 - 08:52 PM
Hmm, could be just from the input shaft vibrating against the splines with a load like many miles down the road in a truck or lots of field work in a PK. It wouldn't wear out the clutch plate just maybe the splines.
#19 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted December 23, 2011 - 08:56 PM
Of course in a big truck you drive thousands of miles and shift gears and the clutch may not be used. I never used the clutch after I got it moving, you just shift without it. I have replaced clutch because the splines in the disc were completely gone, but the lining looked new.
#20 fort apache OFFLINE
fort apache
  • 15 Thanks
  • 137 posts
Posted December 24, 2011 - 02:09 PM
I'm down to it now. Got to the transmission today and I'm gonna pull it monday.
