1972 cub cadet restoration project
44 replies to this topic
#31 KennyP ONLINE
  • 40,874 Thanks
  • 47,091 posts
Posted December 27, 2011 - 01:27 AM
The yellow rockshaft in the first two pics is the original, but has been 'reworked'. It won't work with a Cub PTO anymore. The rest of the stuff is PO mod.
I checked a few places on parts. Rebuilt PTO is $185~, starter pulley/basket $50-$75. Didn't see the rockshaft listed, but they may have one. Otherwise, you will need to find someone with all these parts for a package deal or a donor tractor.
  • Jkrogers said thank you
#32 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Posted December 27, 2011 - 01:13 PM
Thanks KennyP, The PTO is down on my list for now. I am waiting on parts that I need to get it started. I downloaded the parts manual which has been a tremendous help in getting the correct bolts and screws. Thanks for all of your help.
#33 mixedbreed96 OFFLINE
mixedbreed96
  • 11 Thanks
  • 167 posts
Posted December 27, 2011 - 03:19 PM
Great project for you! Have fun with it and good luck!
#34 rdzabel OFFLINE
rdzabel
  • 8 Thanks
  • 16 posts
Posted December 30, 2011 - 10:27 PM
[ATTACH=CONFIG]26963[/ATTACH][ATTACH=CONFIG]26962[/ATTACH][ATTACH=CONFIG]26961[/ATTACH][ATTACH=CONFIG]26960[/ATTACH] Here are some pictures of my 129 I took this afternoon. There are 2 of the front end so you can see what has been removed. Also in the foreground of one shot is the starter generator tensionior arm that you can see someone modified for a longer belt. I also have a picture of the hydro and cover. I think I am missing the lever that contacts the hydro dump buttons? Also, I put the carb back on today and there were two mounting gaskets a thick and a thin in the kit. I used the thick one, am I correct? Thanks and Merry Christmas!
The hydro cover on my 109 is also missing the plate that contacts the hydro dump buttons. Does anyone know what it is supposed to look like, so i could maybe make one. Thanks
#35 KennyP ONLINE
  • 40,874 Thanks
  • 47,091 posts
Posted December 31, 2011 - 04:57 AM
Don't know if this might help but I thought I would give it a try:
#36 rdzabel OFFLINE
rdzabel
  • 8 Thanks
  • 16 posts
Posted December 31, 2011 - 12:44 PM
Thanks KennyP and Amigatec, I will see if I can figure something out, or if all else fails order one.
#37 Cvans ONLINE
  • 7,279 Thanks
  • 6,373 posts
Posted December 31, 2011 - 02:30 PM
129's are really worth the time to fix. I have a nice original 129 if you need any photos or measurements just let me know.
Good luck with your project.
#38 wrbourget OFFLINE
wrbourget
  • 28 Thanks
  • 138 posts
Posted February 13, 2012 - 09:48 AM
I'm looking at three Cub Cadets A 1450,125, and a 70 my question is is the 70 axle housings and the axles the same as a 61 origanal that would be the deal maker for me but i just don't know.
#39 Cvans ONLINE
  • 7,279 Thanks
  • 6,373 posts
Posted February 13, 2012 - 11:58 AM
Jkrogers If you need parts for your 129 let me know as I removed all of the lift parts a other parts that weren't needed for the construction of the Dumpster. That was a CC 149 and 1450. Most if not all the parts will interchange with your 129. Which by the way is my favorite CC.
#40 Cvans ONLINE
  • 7,279 Thanks
  • 6,373 posts
Posted February 13, 2012 - 12:04 PM
I'm looking at three Cub Cadets A 1450,125, and a 70 my question is is the 70 axle housings and the axles the same as a 61 original that would be the deal maker for me but i just don't know.
wrbourget There is one thing you need to know about the 1450's. They use rubber motor mounts and unless someone has changed them they will be in bad shape. Theses mounts also seem to put more strain on the flexible coupler that attaches the drive shaft to the engine. You might want to check these before you start the engine the first time.
#41 IHCubGuy ONLINE
IHCubGuy
  • 1,611 Thanks
  • 1,638 posts
Posted February 13, 2012 - 09:55 PM
The only thing between an Original and a 70 that would interchange is the transmission housing. The axles and housings are completely different between the two as is the front reduction cover. Some engine parts will interchange as well, but for the most part an Original is different animal alltogehter from the other narrow frames.
#42 EricFromPa ONLINE
EricFromPa
  • 4,162 Thanks
  • 3,345 posts
Posted February 14, 2012 - 05:07 PM
I thought you guys might like to see how the PO had the PTO on the 129 rigged up so, I slipped it back on the shaft and took a picture. There are also a couple of shots of the parts that came off the assembly. The rockshaft assembly which has been modified and will need to be replaced. The mower actuating pulley is there and the collar but, I am not sure what or where the other pulley came from. When I purchased it, the deck was on and the belt to the mower hooked up so I assume it worked somehow. Hope everyone had a great Christmas.
WOW a JD PTO on a Cub Cadet.That's the 1st time I've ever seen something like that.
#43 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted February 14, 2012 - 10:08 PM
Post some pics on your progress. I am curious to see your 129 up and running. Good luck and enjoy!
#44 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Posted February 28, 2012 - 09:33 PM
Yes I would be interested in parts. Where are you located?
#45 Cvans ONLINE
  • 7,279 Thanks
  • 6,373 posts
Posted February 28, 2012 - 10:09 PM
If your talking to me, I'm in Eastern SD. About a 100 miles north of Sioux Falls.
