What type grease do you use ?
21 replies to this topic
#16 mjodrey OFFLINE
  • 2,351 Thanks
Posted December 27, 2011 - 06:39 AM
I have been using Lucas Red-N-Tacky NGLI #2 in the summer and NGLI #1 in the winter for about 12 years. Repels water and stays flexible.
Yes,I use that one too,works great.
#17 MH81 OFFLINE
  • 28,446 Thanks
  • 29,126 posts
Posted December 27, 2011 - 09:39 AM
I have always just used "grease". Usually get it from either TSC or the local auto parts place.
Since you guys have mentioned a couple, I may try them when I run out of what's here.
As for the Vaseline, does it have good enough lubrication for actual use or should it only be used for show tractors?
#18 johndeereelfman OFFLINE
johndeereelfman
    Elfin Majic
  • 5,559 Thanks
  • 2,555 posts
Posted December 28, 2011 - 02:20 PM
I use it for all of my show tractors. If you use your tractors hard, and all year long, then I wouldn't recommend using it.
#19 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted December 31, 2011 - 11:34 AM
this is what i was brought up using and i still use it
Valvoline Optimum Choice™ Grease
A partial-synthetic lithium complex grease for extended service intervals and severe-duty service
Viscous base stock provides exceptional water washout resistance, reduced squeeze-out due to heavy loading and high-temperature performance
High molecular weight polymers provide excellent adhesion and tackiness properties
Formulated with anti-wear
#20 Alc ONLINE
  • 5,927 Thanks
  • 6,890 posts
Posted December 31, 2011 - 12:24 PM
Gary , how does this grease hold up as far as getting hard and drying out ? I replaced a truck spring the week and tried the red Valvoline for the spring pins just to see how well that does , Al
#21 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted December 31, 2011 - 03:42 PM
im not sure i may have to go over to dads and look at some of the old machinery and check .
#22 Rick Brumback OFFLINE
Rick Brumback
  • 19 Thanks
  • 124 posts
Posted January 01, 2012 - 02:01 PM
I like the white lithium stuff myself.
