New to the site. H14 owner for about 10 years now.. Recently ive been having issues starting it. I have to constantly press the brake slowly but if I dont get it I have to release it and try again to get it to start. Is it something simple or is there a way to bypass having to press the brake to start it??
H14 Brake issue
Started by
TNUTZ
, Dec 21, 2011 05:09 PM
4 replies to this topic
#1
OFFLINE
Posted December 21, 2011 - 05:09 PM
#2
ONLINE
Posted December 21, 2011 - 05:41 PM
First off, Welcome to the Forum!
Sounds like the brake interlock safety switch may need adjustment.... Here is the owner and operation manual for the H14.
http://sonnys_bolens...uals/H14-OM.pdf
The interlock switch adjustments are shown starting on page 14
We would love to see a few pictures of your Bolens when you get a chance
#3
ONLINE
Posted December 21, 2011 - 06:09 PM
As Brian said, sometimes it is just an adjustment. .....Other times it is a switch failing and needs replacement.
If you are not concerned with eliminating this safety feature, you can disconnect the connector from the switch and make a jumper that goes across the two terminals of the connector. .....Make sure you insulate your connections so that they can not contact a ground.
#4
OFFLINE
Posted December 21, 2011 - 07:37 PM
Welcome to GTTalk TNUTZ. As others have said sounds like an interlock switch problem. Good luck getting it sorted out.
#5
OFFLINE
Posted December 22, 2011 - 08:24 AM
I rewired mine and bypassed all the interlock safety switches, Let me know if you want the "modified" wiring diagram.
