Problem with a briggs and stratton
19 replies to this topic
#16 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted June 01, 2010 - 09:24 AM
How did you make out Nitris?
#17 Nitris OFFLINE
Nitris
  • 7 posts
Posted June 02, 2010 - 10:18 AM
Have been tied down with kids of late have not had time to work on it, but have been working on another issue, Seems my 11 HP Briggs has a little problem. The intake valve ring keeps slipping out when you have run for a time and shuts it down. Take the head off rotate the motor and reseat the ring you'll run for a time longer til it does it again. Any idea how to fix this problem?
#18 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted June 02, 2010 - 10:28 AM
You mean the valve seat keeps working it's way out? If that is the case I wouldn't run it anymore until you get it taken care of, don't want to wear out the bore anymore then what it has already done. This is one area I have no experience in. If I am not mistaken the valve seats are supposed to be a tolerance fit.
#19 Nitris OFFLINE
Nitris
  • 7 posts
Posted June 02, 2010 - 10:39 AM
Yes that would be it, I have not run it since.
#20 jdslednut OFFLINE
jdslednut
  • 680 Thanks
  • 851 posts
Posted June 02, 2010 - 03:04 PM
Probably should have a new seat installed and a valve job but if you want a quick fix you can "peen" the area around the valve seat with a small punch to cinch the seat in place.
