Shaw Du-All -19
  • This topic is locked This topic is locked
43 replies to this topic
#31 mjodrey OFFLINE
  • 2,345 Thanks
Posted December 27, 2011 - 06:35 AM
That's fab-a-mundo Ray.:D:yelclap:
  • jdcrawler said thank you
#32 Michiganmobileman OFFLINE
Posted December 27, 2011 - 09:57 PM
That will be a nice finishing touch for your tractor Ray. Nice Job:thumbs: or as Maynard says "That's fab-a-mundo Ray".
#33 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,182 Thanks
  • 1,728 posts
Posted December 28, 2011 - 07:03 PM
I've always liked the phrases the Canadians use, aye.
#34 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,182 Thanks
  • 1,728 posts
Posted December 29, 2011 - 05:38 PM
The lift mechanism turned out not to be mounted anything like I had originally visioned.
So I cut the angle iron brace out from between the rear part of the frame rails and replaced it with a section of round tube.
A piece of angle iron is then welded in-between the frame rails in front of the rake.
I made up two brackets to hold a 3/4 inch diameter pin and welded these brackets on top of the angle iron.
These will be the pivot mounts for the lift mechanism.
From what I understand, the lift mechanism should hold the rack at different heights but still let it float so it can ride up higher than that point if needed.
Rather than a lift strap with a slot in it, I've decided to use a chain to lift the rake.
This chain that is attached to a bolt on one end will allow some fine adjustment in the height of the rake.
I found a steel bar that has a piece of steel strap formed into U-shape on one end.
The bolt on the end of the chain fits thru this nicely.
This will be used as the arm to lift the rake.
I cut a piece of round stock that will get bored out for the 3/4 inch pin and it will be the pivot mount for the lift arm.
There was a lever on the back of the tractor that I figure was supposed to be used for a plow lift.
The locking mechanism was rusted up on it so I took it all apart and sandblasted everything.
Here's the lever with all the parts reassembled and it is welded to the lift arm.
the lift lever assembly is then mounted on the rake frame.
A piece of strap steel is bent into a "U" shape and welded to end of the control arm on the rake.
The end of the lift chain is attached to this with a pin.
There wasn't any type of ratchet plate for the lever mounted on the tractor so I have to make one.
This is the ratchet plate with the radius cut on the top but no notches cut into it yet.
Another piece of angle iron is welded in-between the frame rails to mount the ratchet plate on.
The ratchet plate will bolt to a piece of angle iron that will be welded to the frame.
Here I'm lining everything up so the bolt holes can be marked for mounting the ratchet plate to the angle iron mount.
The mounting holes are finished and the angle iron mount is welded in place.
Now the ratchet plate can be marked for cutting the notches.
The notches are being milled into the ratchet plate.
Everything is bolted back together so I can see how the lift lever works.
Here the rake is lifted all the way up.
Then to the second notch.
then to the third notch.
And to the fourth notch.
This is adjusted so the rake is about 3/16 off the ground.
A paint stir stick will just slide under the tines.
The lever will rotate a little past the fourth notch to let rake ride a little below ground level.
One last thing to do before it is finished.
I bought four, cup style freeze plugs that will be used a "hub covers" on the wheels.
The two on the left, have 3/8 inch holes drilled in them and will bolt on the outside of the wheels.
The two on the right, have 3/4 inch holes drilled in them and will fit on the inside of the wheels.
The inside lip of the cup will fit up over the hub on the wheels and help keep dirt from getting down into the bushings.
Leather washers will be made up to fit inside the cups to help seal the grease in and keep the dirt out.
The cups for the inside of the wheels are welded to the rear frame on both sides.
#35 KennyP ONLINE
  • 29,393 Thanks
  • 40,388 posts
Posted December 29, 2011 - 05:49 PM
Boy, you just keep raising the bar! Excellent work on this, I never would have thought of the wheel bushings. You make it all sound so simple. Now tell me how to do this without a mill, lathe, or tube bender.:bigrofl:
#36 tinner OFFLINE
tinner
  • 502 Thanks
  • 1,561 posts
Posted December 29, 2011 - 05:53 PM
Great project and it's looking good. Can't wait to see the finished product.
#37 MH81 ONLINE
  • 27,980 Thanks
  • 28,935 posts
Posted December 29, 2011 - 06:14 PM
As cool as these pics are, I bet seeing them up close is even better. Thanks so much for the tour and taking the time to document.
#38 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,182 Thanks
  • 1,728 posts
Posted December 29, 2011 - 07:19 PM
You got me there, Ken
It's a no-go without the tools to make the parts.
#39 Lovintractorin OFFLINE
Lovintractorin
    Tinkerer
  • 159 Thanks
  • 603 posts
Posted December 29, 2011 - 07:58 PM
It is looking great, Ray. :thumbs:
#40 wvbuzzmaster OFFLINE
  • 4,494 Thanks
  • 7,341 posts
Posted December 30, 2011 - 01:56 AM
First of all, that is great fab work again today Ray. Just when I thought I had you figured out you go and think of dust caps on the wheels lol.
Hey Kenny, I think Ray would still accomplish it, just in a longer time frame because he will have to rub a lot of lamps to find one with a genie in it LOL.
#41 KennyP ONLINE
  • 29,393 Thanks
  • 40,388 posts
Posted December 30, 2011 - 02:39 AM
I have to rely on 'schazam' to do something like that.:bigrofl:
#42 mjodrey OFFLINE
  • 2,345 Thanks
Posted December 30, 2011 - 05:20 AM
I don't know what else there is to say.You're da man,Ray.:thumbs:
#43 tractorman604 OFFLINE
tractorman604
  • 269 Thanks
  • 694 posts
Posted December 30, 2011 - 08:09 AM
Great work Ray! I alway's enjoy looking at your EXCELLENT craftsmanship.
#44 MH81 ONLINE
  • 27,980 Thanks
  • 28,935 posts
Posted August 28, 2016 - 09:19 AM
Next phase of the project can be found here
http://gardentractor...shaw-du-all-20/
