uh-oh, lots of brake fluid on the ground!?!??
31 replies to this topic
#31 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted January 07, 2012 - 02:46 PM
I'm not sure of the rates in your area. You may be able to find a 3rd party auto shop to do the work at a reduced rate. I would give the local JD dealers a call and see if they will give you an estimate. The parts are not expensive and if you had an experienced mechanic it would not be a big job for them as long as the problem is only the bearing and seal.
#32 mikastorm OFFLINE
mikastorm
  • 7 posts
Posted January 07, 2012 - 08:46 PM
You could go here and see if you get a reply. Its in your neighberhood.
Help Wanted / Looking for Work ?? - Check here!!
