MF 10 Ign switch
17 replies to this topic
#16 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted January 16, 2012 - 09:17 PM
I have a new problem with the switch. Does any body know if the terminal marked C is switched? I tested the switch without anything hooked up to it and that terminal was switched. I used that terminal to turn my solenoid on and off for the power lift. When I hooked it all up the power lift works with the ignition switch off, it should not do this. The same terminal on the switch goes to the center pin of the rectifier. I pulled all the wires off the switch and checked it again and C is switched but when I put the wires back on that terminal is hot all the time. I have looked my wiring over and can't find a problem. So I am at a loss for now. I will check on it some more tomorrow night.
#17 DanP OFFLINE
DanP
  • 330 Thanks
  • 491 posts
Posted January 18, 2012 - 07:21 AM
I found the problem, my brand new solenoid is deffective. It is stuck in the on position all the time, so I have to return it and get another one I hope.
#18 KennyP OFFLINE
  • 53145 Thanks
  • 53295 posts
Posted January 18, 2012 - 07:56 AM
Glad you figured it out, Dan.
