battery or maybe solinold
7 replies to this topic
#1 cfd46 OFFLINE
cfd46
  • 1 posts
Posted December 19, 2011 - 07:49 AM
Having problems starting my ac 608lt.
It does start sometimes battery is new its at 12.6
Volts theres juice going to the solinold and
Starter. In ordet to start it i have to jump start
It via solinold could it be bad?
#2 caseguy OFFLINE
  • 1,628 Thanks
Posted December 19, 2011 - 08:26 AM
:wave: cfd46 Welcome to GTTalk! When you say "jump start", do you mean the screwdriver across the high current terminals of the solenoid, or are you jumping the coil side? If your jumping the coil side, it could be your key switch. If it starts sometimes, it could be a bad connection or a wire that's going bad. It could even still be the key switch or a sketchy ground connection. Sorry to not be more concise, but electrical gremlins, especially intermittent ones, can be a bear to nail down. If you could provide some more details, we may be able to help you narrow it some more.
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted December 19, 2011 - 09:15 AM
As said above, make sure you have a good ground (engine chassis) connection back to the battery - terminal. Many times this gets ignored or taken for granted but it can cause you all kinds of grief if it's not a really good low resistance connection.
#4 plowboy OFFLINE
plowboy
    TRACTOROLOGIST
  • 133 Thanks
  • 229 posts
Posted December 19, 2011 - 09:44 AM
having issues as well in my Sears. i have 2 batteries that i know are both good. i actually jump start the battery off my car & the tractor starts rght up. i shut it off & no start again. im thnkn i may be wrong & the batteries may both be shot :-(
#5 DougT OFFLINE
DougT
    Dog Approved
  • 6,928 Thanks
  • 4,996 posts
Posted December 19, 2011 - 03:19 PM
Caseguy is on the right track here. Another thought would be safety switches in the circuit.
#6 MH81 OFFLINE
Posted December 19, 2011 - 05:58 PM
If you have a volt meter, put it on the battery & try to start. Probably see 12+ volts drop to 3 - volts. If so, you have a bad cell in the battery and no amount of messing with it will fix it.
  • plowboy said thank you
#7 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted December 19, 2011 - 06:37 PM
My Craftsman had that type of trouble. Turned out the Battery Terminal on the back of the key switch had corroded in half.
#8 MH81 OFFLINE
Posted December 19, 2011 - 07:50 PM
Yep, that could do it too... just not show the voltage drop.
