How do transfer pics?
16 replies to this topic
#1 IamSherwood OFFLINE
  • 8,395 Thanks
Posted December 14, 2011 - 07:34 PM
I have a new laptop with Windows 7.
My old one has vista, and about 2500 pictures, set up in folders.
I have a 8GB memory stick.
Is there a way to transfer the pics and the folders, so I don't have to
sort them all out?
Thanks
#2 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted December 14, 2011 - 07:38 PM
How big is the file?
#3 olcowhand ONLINE
  • 42,455 Thanks
  • 31,824 posts
Posted December 14, 2011 - 07:48 PM
Can't you connect the laptops via double ended USB cable & do a simple transfer direct....or will Win 7 & Vista not talk civil?
#4 IamSherwood OFFLINE
  • 8,395 Thanks
Posted December 14, 2011 - 07:56 PM
1.26 GB
I just noticed, that when I loaded the pics on to the memery stick, it did take the folders with.
But, when I tried to take them off the stick, Win7 didn't take the folders.??
#5 caseguy OFFLINE
  • 1,629 Thanks
Posted December 14, 2011 - 07:57 PM
The two versions of windows should communicate just fine, but windows 7 is ridiculous with all the privacy "upgrades". It would probably be easier just to drag and drop the image folders into the thumb drive and then drag and drop them to the new computer. If Windows 7 has compatibility issues with the folders, try opening them in compatibility mode. (Right click on the folder and you should see the option.)
#6 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted December 14, 2011 - 08:05 PM
your 8 GB stick should work fine.
Option 2 is use Dropbox. https://www.dropbox.com/install
#7 MH81 OFFLINE
Posted December 14, 2011 - 08:13 PM
I would probably just use the thumb drive, but there are a couple other ways to do it.
If you happen to have a transfer USB, that would be easiest... But DO NOT use a regular USB. It will burn our a pwr supply somewhere. The transfer USB cables have a module in them that keeps the power separate. (you might find one at a Staples or Radio shack)
The other way to do it is with a cross-over cat5 ethernet cable. (you probably would have to order this)
If you have a wireless router, lots of them have multiple Ethernet ports on them, you could hook both computers to it and set up a home network. From what I understand, you should set up the Win 7 machine first, then the older one, using the disc you just made on the win 7 machine.
  • ducky and Texas Deere and Horse have said thanks
#8 IamSherwood OFFLINE
  • 8,395 Thanks
Posted December 14, 2011 - 08:50 PM
Ok, got it done. Thanks guys.
#9 MH81 OFFLINE
Posted December 14, 2011 - 09:04 PM
And how did you do it? LOL
#10 IamSherwood OFFLINE
  • 8,395 Thanks
Posted December 14, 2011 - 09:08 PM
copy and paste.
#11 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted December 14, 2011 - 09:35 PM
That a way Will.
#12 kb0nly OFFLINE
kb0nly
  • 18 Thanks
  • 63 posts
Posted December 15, 2011 - 01:49 AM
Was just going to comment... See you got it.
When you put a memory stick or otherwise in a Win 7 machine it will pop up the wizard if it finds photos, just browse it instead and then copy and paste like you did.
However, when you put in a memory card from a camera this is quite handy, you can set it to copy all the pictures off the card into dated folders, then have it erase the card, and its ready to go back into the camera in one click!
  • IamSherwood said thank you
#13 KennyP OFFLINE
  • 40,192 Thanks
  • 46,794 posts
Posted December 15, 2011 - 04:54 AM
Glad you have them copied over. I have my laptop on a network, been copying and pasting so I have a backup for this computer if I need it. Makes it easier to use it to post with too.
#14 mjodrey OFFLINE
Posted December 15, 2011 - 05:13 AM
copy and paste.
Good for you ,Will.:thumbs:
#15 poncho62 OFFLINE
poncho62
  • 1,996 Thanks
  • 1,744 posts
Posted December 15, 2011 - 07:20 AM
I just copy the whole picture folder to a disk and do it that way.....Keep the disk as a backup, you never know when your computer might crash
  • ducky said thank you
