Tires with snow blower
#1
OFFLINE
Posted December 11, 2011 - 05:23 PM
The problem is, the blower is so heavy it squashes the front tires. Is there an alternative to the turf saver tires for the front that will hold more pressure? With the maximum 12 lb the sidewalls almost hit the ground with the blower lifted.
#2
OFFLINE
Posted December 11, 2011 - 05:49 PM
#3
ONLINE
Posted December 12, 2011 - 08:12 AM
#4
OFFLINE
Posted December 12, 2011 - 08:42 AM
My last tractor you could side the rear end around with 2 fingers when the blower was up,
#5
OFFLINE
Posted December 12, 2011 - 08:53 AM
Edited by Gtractor, December 12, 2011 - 08:58 AM.
#6
OFFLINE
Posted December 12, 2011 - 08:58 AM
The common solution is to load the rear with weights to offset the weight on front.
I have loaded the rear tires, and added 120 lb of iron weights to the rear. This helps with traction, but it poor front tires are squished.
I wonder if loading the front tires with liquid would help.
#7
OFFLINE
Posted December 12, 2011 - 09:00 AM
#8
OFFLINE
Posted December 12, 2011 - 11:01 AM
#9
OFFLINE
Posted December 13, 2011 - 12:03 AM
My Ariens has 13x5x6 on the front and they have a max rating of 40lbs in them, one wouldn't hold air for long, think it was a bad bead seal so i put tubes in both of them. The manual for my tractor says to put 16lbs in the fronts but the tires say right on them they are rated for much more. I put 25lbs in the front tires after adding the tubes, the ride feels much better with the weight of the blower on the front. I have wheel weights and a weight box but the Ariens blower attachment is a heavy bugger and the tires were still squated a fair amount.
#10
ONLINE
Posted December 13, 2011 - 11:59 AM
#11
OFFLINE
Posted December 13, 2011 - 02:30 PM
you could foam fill the tires
#12
OFFLINE
Posted December 14, 2011 - 07:21 PM
Just guessing, the blower weighs around 400 lbs and is about 5 feet from the rear axle. Rear weights are about 1 foot behind the rear axle. This means for every pound of reduction on the front tires, I would need 5 pounds of weight rear.
So if I want to reduce the load on the front tires to 200 lbs, I will need to add 1000 pounds of weight to the rear. I do not think the frame or rear tires would handle that ;{
#13
OFFLINE
Posted December 14, 2011 - 07:36 PM
...You need to look at wider or stronger(more plys and higher pressure rating) tires for the front.
I agree with Brian on this one. I see what you're saying and your math is correct, but the distance should be taken from the center of the rear axle. If you have a hitch setup on the back, you're probably 2 feet back from the center of the axle. You're not trying to offset the entire weight of the blower, just decrease the load on the front tires. Heavier tires combined with some weight behind the rear wheels will certainly help.
#14
OFFLINE
Posted December 15, 2011 - 01:52 AM
I have wheel weights on the rears for traction weight, i also have the factory weight box that goes on the back to add more weight to offset the blower. I keep two concrete blocks and my 5 gal gas jug and a small toolbox back there. Its probably only about 60-70lbs when the gas jug is full but its enough to feel the difference. However, adding weight behind the axle also puts that weight on the axle, that is it becomes a load on it. Adding weight to the tires doesn't put extra pressure on the axle, it only adds rolling resistance.
#15
OFFLINE
Posted December 18, 2011 - 11:09 AM
