HT-20 Questions...
#31
OFFLINE
Posted January 05, 2011 - 05:46 PM
Could be expensive getting it shipped to Scotland. Hell of a job getting it in a suitcase!!!!!!!!!!!!!!
#32
OFFLINE
Posted January 07, 2011 - 10:04 AM
Here are the pictures of my tractor as promised.
I have tried to show my efforts at making a weight box and also some wheel chains. I hope not to have to use the chains. I can always increase the amount of 56lb weights in the box.
The snowplough main mechanism is off a ride on mower. Buying this saved me a lot of work fabricating the pivot and spring part. A bit of flat sheet, bent under my van wheel, makes up the extra width needed. I can always strip back the original plough and sell it again if need be.
The 2 orange things are snow shovels, for the tricky bits!!
Do you think I should paint the tractor back to white, or leave it red and get some decals made for the bonnet.
#33
ONLINE
Posted January 07, 2011 - 05:09 PM
[ATTACH=CONFIG]9005[/ATTACH][ATTACH=CONFIG]9007[/ATTACH][ATTACH=CONFIG]9008[/ATTACH][ATTACH=CONFIG]9006[/ATTACH][ATTACH=CONFIG]9004[/ATTACH]
You have a good looking Tractor there
I'm sort of a purist so I would say paint her back to original colors, but If you want it red it will still look good
- joiner said thank you
#34
OFFLINE
Posted January 07, 2011 - 05:34 PM
#35
OFFLINE
Posted January 13, 2011 - 06:14 PM
Does any body have any pictures of how the rear pto setup works. Have downloaded plenty pictures etc of how the 3 point linkage works, so might possibly try fabricating it next,,, after I try and design and make a front tipping bucket. This will be a stop gap item until I can find parts to make a loader.
Is it Ok to turn the exhaust from horizontal to vertical without any bracing straps. I am a bit worried about the manifold. Will the 4 bolts keep it supported enough
without the risk if cracking.
#36
OFFLINE
Posted January 13, 2011 - 06:24 PM
#37
OFFLINE
Posted January 19, 2011 - 06:06 PM
Another question for you experts. There is a QT17 for sale over here on ebay. Are the back ends the same, and could the engines be swapped over if need be. What years were the QT17`s made. The seller says that the tractor is not running. Will try and email him to see what the problems are. Are there any inherint problems with these tractors??
Still looking for info on the HT20 rear PTO set up. What speed does the front PTO turn at, and is it clock wise or anticlockwise turning. Asking with regards to a hyraulic pump for my future loader.
Seem to have taken a liking to these Bolens!!!!
#38
ONLINE
Posted January 19, 2011 - 06:19 PM
If i'm not mistaken, the QT 17 was made only in 1979 and came with a Kohler KT17QS-24106A. It had an Eaton 11 Transmission.
The HT 20s used The Sundstrand 15 Transmission.
So the Transmissions are two different kinds.
I 'm not sure on how easy it would be to swap engines but you would be getting less power if you were to use the QT's engine.
The QT's are known as the "medium frame" Bolens while the Ht series is in the Large Frame category. (The likely hood of any parts being interchangeable is slim to none>)
#39
OFFLINE
Posted January 19, 2011 - 06:24 PM
- Bolens 1000 and joiner have said thanks
#40
OFFLINE
Posted January 20, 2011 - 01:30 PM
Anybody got info on the rear PTO????????
#41
OFFLINE
Posted March 17, 2011 - 06:02 PM
I have been making a wooden cab ( use what you have got!) for the tractor over the last few weeks ( pics to follow ), but have now taken the tinwork off to get it blasted, and I will then get it painted back to white. I will blast and paint the wheels when I can afford new tyres.
Which decals should be on the tractor. I have seen two types. The ones without the FMC part look to be from the early tractors. Am I correct in thinking this. Also is it possible to tell the age by the chassis number. I am trying to register the tractor for highway use but the authorities want the approximate age of the machine. The chassis number is---0201096---
Was at a sale last weekend and almost bought a J*** D**** 400 with 60" deck and trailer to move it with. Chickened out at the last second. Was I wise to do that!!!!!!!!!! Would have loved the POWER STEERING.
Am in the process also of welding up a bucket for the front. It will be a johnny bucket style to start with until I can find reasonably priced parts to make a loader. The bucket can then be used on the loader. What is the biggest ram that can be used, with the original hydraulics, without causing problems. Have read of some using a loader from the main pump. Is that a bit brave.
Any advice would be greatly appreciated.
Thanks
#42
OFFLINE
Posted March 18, 2011 - 01:11 PM
Thanks
#43
OFFLINE
Posted March 18, 2011 - 04:36 PM
#44
OFFLINE
Posted March 18, 2011 - 05:33 PM
Any one got any clues on the age from the chassis number??
#45
OFFLINE
Posted March 18, 2011 - 06:47 PM
As for the year give me the model and serial number and i will see what i can find.
