* * * * * 2 votes
One Inch Thick.......
93 replies to this topic
#31 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted December 12, 2011 - 08:39 AM
Duck tape!!!!!!!
:bigrofl::bigrofl::bigrofl::bigrofl::bigrofl::bigrofl::bigrofl:
#32 KennyP ONLINE
  • 37,426 Thanks
  • 45,465 posts
Posted December 12, 2011 - 11:31 AM
Okay, kidding aside for a moment! Do you all think I can get by with putting 3 studs on each wheel to mount the rotors on, then the lead on to the rotors? Or should I go ahead with all 5? I will set this up to mount the rotors on top of the wheel nuts so I don't have these rubbing the wheels when they are installed. I hope to have about 50-70 lbs. all together per wheel.
#33 olcowhand OFFLINE
  • 40,350 Thanks
  • 31,170 posts
Posted December 12, 2011 - 11:52 AM
3 should do just fine, but wondering if you plan to use all-thread for this? Are your threads coarse or fine. Never looked for fine thread all thread before....is it available?
#34 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted December 12, 2011 - 11:59 AM
yes, it's avalable Daniel
#35 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted December 12, 2011 - 12:22 PM
you can get all thread in fine or course, and you can get it in grade 5 and grade 8. There are a lot of GT's out there that only used 3 lug bolts orginally. All my Sub's work this way and the weights just slides down over longer studs. Mine are not all threaded, but in fact studs, with about an inch of thread at the rim/ a nut. There is a second set of nuts and a flat washer on the outside.
#36 KennyP ONLINE
  • 37,426 Thanks
  • 45,465 posts
Posted December 12, 2011 - 12:23 PM
Just got to looking. I can get a 2' piece of B7 7/16"-20 from McMaster-Carr for $3.79. I can get a box of 25 lug nuts from NAPA fairly cheap. If I use three studs, need 12 nuts. Have a few extra. This will set the inside of the rotor about 3/8"-1/2" out from the rim. That's why I was wondering if 5 might be better with all that weight hanging out there.
#37 KennyP ONLINE
  • 37,426 Thanks
  • 45,465 posts
Posted December 12, 2011 - 01:04 PM
Lauber1, are those 7/16"-20 by chance? I tried looking at NAPA for something similar, but gave up at 500 items out of 1800+/-.
#38 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted December 12, 2011 - 01:31 PM
i beleive that they are. I know there 7/16 fine, but dont know the thread count. My weights are 50# on just the 3 bolts so you shouldnt have any problems with your. You could also use a short closed pipe nipple as spacer to move you weights out farther.
#39 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted December 12, 2011 - 03:15 PM
That would be Heavy Duty. That other "HD" word you mentioned (Orange Depot?) is not used in my home. Causes hives.:mad2:
#40 Cvans OFFLINE
  • 6,455 Thanks
  • 6,052 posts
Posted December 12, 2011 - 03:41 PM
If you have a Fastenal distributor in your area they have the fine thread all thread. At least ours did when I needed it.
#41 olcowhand OFFLINE
  • 40,350 Thanks
  • 31,170 posts
Posted December 12, 2011 - 05:33 PM
Yep, Fastenal is near me too. All I've ever bought is coarse thread readi-rod myself.
#42 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted December 12, 2011 - 06:10 PM
Wow, now I know I have been out of the loop. At first I thought this was that other guy's thread and then I read the thread title and didn't see plate and then I thought maybe someone was confessing......... :bigrofl:
#43 KennyP ONLINE
  • 37,426 Thanks
  • 45,465 posts
Posted December 12, 2011 - 06:34 PM
Welcome to GTTalk, NUTNDUN! Glad you joined in on the fun.
#44 Sparky OFFLINE
Sparky
  • 1,296 Thanks
  • 1,892 posts
Posted December 12, 2011 - 10:07 PM
Member J1Morris kindly offered info that left handed lock washers could be found at aviation hardware sources in the thread " Left handed lock washers " started by me . His post was 8-20-2011. As for re-cycling things yeah there are good ideas like Kenny's. The rest was a little ( shuck and jive ) . The best farm tractors were prototyped in farmers' barns - Wagners . Steigers , my uncle's home made self propelled chopper in 1948 with two engines . A flathead Ford drove the chopping wheel . A good post - all true.
#45 KennyP ONLINE
  • 37,426 Thanks
  • 45,465 posts
Posted December 13, 2011 - 05:01 AM
I would like to find the studs Lauber1 speaks of, guess I'll muddle thru the Napa site and see what I find. Thanks to Toolpartzman, I have the turkey fryer coming. Now to find some "one thick titanium plate" for the outside sandwich.:bigrofl: And a physicist to machine it!:bigrofl::bigrofl:
