propylene glycol
10 replies to this topic
#1 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted December 11, 2011 - 08:43 AM
a friend of mine is working on a job where there taking out a old chiller system . they pumped the system out and ended up with 4 1/2 barrels of propylene glycol .i know it is not toxic because its coming from a food plant. but some time when we fill these systems we add corrosion inhibitor and i know this system has it in it i put it in 6 years ago . im getting a 55 gallon drum of this used fluid and was wondering if any one has used it before . he said the piping looked good inside but the fluid is moving all the time . in a tire it will be sitting alot and i dont want it to eat the rims ever .
#2 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted December 11, 2011 - 09:09 AM
Put tubes in the tires and never look back :thumbs:
#3 KennyP ONLINE
  • 40,888 Thanks
  • 47,094 posts
Take some and put a piece of metal in it over the winter. That will let you know what it will do.
#4 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted December 11, 2011 - 09:20 AM
thats what i may do . i doubt you cant just go to your local JD dealer and get a set of JD 400 rims anymore . i know this fluid shouldn't corrode steel but ill be thinkin about it all the time .
#5 Cvans ONLINE
  • 7,288 Thanks
  • 6,376 posts
Posted December 11, 2011 - 09:44 AM
We used it in our closed loop refrigeration systems. I don't recall it ever reacting negatively to anything it came in contact with. I guess I wouldn't hesitate to try in my tires. When we tore our systems down years later the glycol and piping looked like new.
#6 olcowhand OFFLINE
  • 42,896 Thanks
  • 31,939 posts
Posted December 11, 2011 - 09:46 AM
I'd put it in my tubeless without hesitation.
#7 70Blazer OFFLINE
70Blazer
  • 10 Thanks
  • 61 posts
Posted December 11, 2011 - 02:55 PM
Kinda off subject a little, but this is a component used in the electronic cigarette industry. It's used to blend flavors into the liquid used to smoke(vaporize). I use it myself along with vegetable glycol...yummy.
#8 dave8338 OFFLINE
dave8338
  • 196 Thanks
  • 374 posts
Posted December 12, 2011 - 11:25 AM
Use it. It is nothing more than a "fancy" sugar and won't hurt a thing. Tubes or not.
#9 NUTNDUN OFFLINE
  • 10,352 Thanks
Posted December 12, 2011 - 06:23 PM
I agree and as a user of it too I approve this message :D
#10 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted December 12, 2011 - 06:58 PM
Lol
#11 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted December 12, 2011 - 07:06 PM
It's used in solar water heating systems and the thing you have to watch out for is that it will go acidic if overheated for long periods and then it can cause corrosion to start. Part of the regular maintenance of a solar HW system is to test the PH now and then. It would be an excellent choice for wheel weight IMO.
