moldboard plow
21 replies to this topic
#1 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted December 10, 2011 - 07:48 PM
do u guys think this will be a good plow to use on my panzer and murray.
10 in. Moldboard Plow-PP-51BH at The Home Depot
#2 olcowhand ONLINE
  • 40,373 Thanks
  • 31,177 posts
Posted December 10, 2011 - 07:54 PM
It will work if you have sleeve lift on your tractors. If 10" cut is more than your tractor wants to handle, you can adjust it to only take a partial cut.
#3 MH81 OFFLINE
Posted December 10, 2011 - 08:02 PM
I think that Panzar should handle it, no problem. You will have to do a little engineering to get the sleeve hitch right tho.
#4 olcowhand ONLINE
  • 40,373 Thanks
  • 31,177 posts
Posted December 10, 2011 - 08:04 PM
I really wouldn't want to attempt pulling a plow with the Murray though. Not picking on it at all, as they are good lawn tractors....just they don't have a transaxle really up to the task of plowing & could blow the gears.
#5 BushBoneYard OFFLINE
BushBoneYard
  • 36 Thanks
  • 70 posts
Posted December 10, 2011 - 08:10 PM
The Murray should have a Peerless 2300, just like my Murray Built ST 10. Murray recommended an 8" plow.
Edited by BushBoneYard, December 10, 2011 - 08:21 PM.
#6 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted December 10, 2011 - 08:25 PM
JohnBoggs21 has a Murray he uses a three tooth ripper/cultivator on in high gears. He abuses that Murray too.
#7 BushBoneYard OFFLINE
BushBoneYard
  • 36 Thanks
  • 70 posts
Posted December 10, 2011 - 08:31 PM
I know John from another site. He does take that lt to task lol.
The Murray Garden Tractors are an under rated bunch, especially the 1977-1989 machines.
#8 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted December 10, 2011 - 08:41 PM
John has morphed that Murray into everything he has ever needed. Only Murray I know that has real hydraulics on it LOL.
#9 olcowhand ONLINE
  • 40,373 Thanks
  • 31,177 posts
Posted December 10, 2011 - 08:42 PM
I stand corrected on that Murray! I figured them to have the key shift type transaxles. The 2300 is the same trans as the JD 200 series, so it should handle the plow fine.
#10 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted December 10, 2011 - 09:27 PM
i need the bottom part of the sleeve hitch the U shaped piece that the plow attaches to. anyone have one they could sell
#11 johnboggs21 OFFLINE
johnboggs21
  • 18 Thanks
  • 184 posts
Posted December 11, 2011 - 08:54 PM
actually its a 5 tooth lol
Its a murray, it does work lol
#12 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted December 11, 2011 - 08:58 PM
My mistake! LOL
#13 johnboggs21 OFFLINE
johnboggs21
  • 18 Thanks
  • 184 posts
Posted December 11, 2011 - 10:46 PM
as intrigued by it as you were the first time you seen it, i thought for sure you would know its a 5 lol
#14 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted December 11, 2011 - 11:08 PM
When I start talking about it even you will believe whatever I tell you about it LOL.
#15 johnboggs21 OFFLINE
johnboggs21
  • 18 Thanks
  • 184 posts
Posted December 12, 2011 - 06:37 PM
KC, put the bottle down and step away from the keyboard. Now your not making any sense to ME, and ive been deciphering your BS for years lol
