JD212 transaxle LIVES Again! ATTN: TD&H
13 replies to this topic
#1 olcowhand OFFLINE
  • 42,434 Thanks
  • 31,812 posts
Posted December 10, 2011 - 03:45 PM
Just finished installing the repaired transaxle back into the JD212 that I traded to Brian (TD&H). Had the right axle snapped off clean right behind the spider gear in the diff. Put a couple new seals in also. Just took it for a spin & all is working perfectly! Just running off jumper box, so hood has to stay up.
Here's a video of a short run in high gear.
Edited by olcowhand, December 10, 2011 - 06:45 PM.
#2 Alc ONLINE
  • 7,128 Thanks
  • 7,532 posts
Posted December 10, 2011 - 03:53 PM
Good to hear you got everything back together , you just might enjoy those green tractors after all , Al
#3 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted December 10, 2011 - 04:16 PM
Glad you got it all repaired Dan, so what's next, restore the 212 for TD&H? LOL.
#4 Tmo OFFLINE
Tmo
  • 360 Thanks
  • 486 posts
Posted December 10, 2011 - 05:20 PM
Dan,
I have been into a couple of these 2300 Peerless transmissions. Since you had to replace an axle, did you replace the detent springs in the shifter forks? The most common problems in these transmissions is a weak or broken detent spring in the shifter fork, which will cause the transmission to slip and if not corrected, will damage the gears. The springs are cheap and can save a more expensive repair down the road.
As for the axle breaking, I picked up a free 210 a few years back that had a busted axle also. Yours and mine are the only ones I heard of having a busted axle. Easy fix, and a good excuse to replace seals, detent springs, check the condition of the gears, etc.
#5 olcowhand OFFLINE
  • 42,434 Thanks
  • 31,812 posts
Posted December 10, 2011 - 05:21 PM
I looked at the detent springs & they looked fine. All gears looked good as well.
#6 Texas Deere and Horse OFFLINE
  • 14,863 Thanks
  • 15,511 posts
Posted December 11, 2011 - 12:09 AM
http://www.youtube.com/watch?v=BRieQUwlS7k
:dancingbanana:WOW Daniel, That thing runs great. I am very happy with the way it sounds and runs. THANKS SO MUCH for going through the Trans-axle for me. Dad is going to be very surprised when he gets this 212 to go along with his 214.:worshippy1:
#7 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted December 11, 2011 - 09:12 AM
that JD sure looks good runnin around the milk farm . ill bet when you started it all the red tractor run and hid:bounce:
#8 KennyP ONLINE
  • 40,173 Thanks
  • 46,783 posts
Posted December 11, 2011 - 09:21 AM
He probably had to chain the Red ones so they wouldn't attack it.:bigrofl: Great video and glad you got it fixed. Got a little seat time, too.
#9 olcowhand OFFLINE
  • 42,434 Thanks
  • 31,812 posts
Posted December 11, 2011 - 09:50 AM
Naw, the red tractors aren't intimidated by green at all. They just sat in the sheds snickering! LOL
#10 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted December 11, 2011 - 11:14 AM
dont you have something to do ,you just keep fixin tractor so we can talk about them . LOL
#11 olcowhand OFFLINE
  • 42,434 Thanks
  • 31,812 posts
Posted December 11, 2011 - 11:16 AM
LOL...I need to get back out & do just that! After milking this morning, I camped out on this computer. Time to get some work done!
#12 Texas Deere and Horse OFFLINE
  • 14,863 Thanks
  • 15,511 posts
Posted December 11, 2011 - 11:18 AM
:bigrofl::bigrofl::bigrofl::bigrofl::bigrofl::bigrofl::bigrofl::bigrofl::bigrofl:
#13 wrbourget OFFLINE
wrbourget
  • 28 Thanks
  • 138 posts
Posted January 01, 2012 - 09:22 AM
I recently got a L130 to replace the Lt110 i have that won't climb hills anymore and is slow, I'm sure I'm going to have the same problems with the 130 as i had with the 110 unless i do a k66 upgrade. Where does this trans axle come from? I can buy an upgrade kit for a mere $1600 but you know if i can figure out what it came in I can get one and do it myself for a lot less money does any one know what model came with this K66.
#14 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted January 01, 2012 - 10:47 AM
i bought a l130 when they first hit the market and used it for four years sold it two years ago and that guy is still using it . i mowed hills ditches weed taller than the mower and never had any trouble with it . you just have to remember its not its not a heavy built garden tractor and its not going to take the abuse like one . but if you take your time and dont ram around it will last along time .i also kept it clean and never let grass build up on the trans axle so it would stay as cool as i possibly could keep it .
